It's official - 2320 owner
   / It's official - 2320 owner #1
Dubeast
Central CT
Kubota B2320
Just an official howdies and a thanks to these forums for all the information which lead to my purchase. I've had the tractor for 2 weeks and 20 hours of engine time now but just signed the paperwork yesterday so it's official.
But for those comparison shopping, I'm in CT and bought from an in-state dealer.
Kubota 2320 Hydrostatic
304 FEL
Ballast Bucket
Land Pride 4ft Box Blade
A&B One Bottom Plow
Clamp on Forks
Tooth Bar
-- just over $18k including taxes
Like so many others it was between the JD2320 and the K2320 but it just came down to deciding that the price diff could pay for a few extra attachments. Originally, started by looking at a BX25 but glad I moved up to the B. The larger frame was a good decision considering what I've been doing.
What I've been doing:
1. Beating back the woods/brush about 20 feet in all directions to expand the yard. Cutting down trees and clearing out all the ground cover.
2. Bringing in fill to to grade out some steep areas and fill in some 'pits'
3. and eventually in the spring will turn over the entire front and back yards and put some 'real' top soil down and re-seed.
By far the best attachments I've used so far has been my neighbor's york rake for cleaning up the woody areas. The one bottom plow has been great for turning over the very hard compact soil and loosening things up. And the box blade has been great for spreading and smoothing things out.
I didn't go for the mowing deck (yet) since I have a JD lawn tractor for mowing which should still suffice for the time being.
I've very happy with my purchase and I've found alot of information in these forums extremely useful towards making this purchase, not to mention again the how-to videos on EverythingAttachments.com.
Thanks
The photos are still in the camera.. when I get them off of the camera I'll upload some.
   / It's official - 2320 owner #4
Patiently waiting.:D:thumbsup:
Congrats and welcome to Green.:)
   / It's official - 2320 owner #5
Congratulations on your new tractor and equipment, sounds like you have the right setup for your property. There are a lot of happy B owners here.
Issue #1
Sigh....The last piece was the tooth bar that the dealer installed today and when I got home it was on the tractor. Unfortunately, the dealer drilled the holes in the wrong spot! He drilled them to the back so I can't loosen them up and flip the tooth bar up. Sigh....
If we re-drill the holes in the correct position how will that affect the integrity of the bucket in the long term? I knew where to drill the holes (thx to these forums) and even told the salesman where they needed to be drilled.
Wondering how the dealer is going to offer to 'fix' the problem.....
   / It's official - 2320 owner #9
Issue #1
Technically speaking the dealer did put them in the right place. I have seen people on this website drill them more forward so they can flip the tooth bar up, but really that's not how a tooth bar is meant to be setup. The bolt goes to the back of the slot, as the bucket edge wears your tooth bar can be slid back accordingly. Also, if you are back dragging with the bucket flat you could pull the tooth bar off if the holes are not at the back. Go look at any skid steer or TLB with a tooth bar and I bet 99% of them are setup with the bolt to the back of the slot.
   / It's official - 2320 owner #10
Congrats on the tractor and implements purchase. The B's are great Compact tractors. If I were going to buy another tractor, I would give the B2320 a very serious look.
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2016 Peterbilt 320...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
2024 JOHN DEERE 1025R LOT NUMBER 106 (A53084)
2024 JOHN DEERE...
2005 Isuzu NPR Venco VC516 Landscape Dump Truck (A53422)
2005 Isuzu NPR...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
