It's harder than it looks
   / It's harder than it looks #21
I've used 1/2" copper for my air lines in my wood shop for over 15 years and for over 10 years in my tractor shed with no problems whatsoever. I'm running 130 psi in both buildings.
Bill
   / It's harder than it looks #22
I am a very good arc welder, I can lay three or four beads on top of one another and line up all the pinholes.:D
And I thought that was my talent (only).
jb
   / It's harder than it looks #24
John I am curious about the problem with the PVC pipe blowing up on you. Did you by any chance have it out in the open where the sunlight could get to it. I have been told that ozone will attack pvc pipe and cause it to break down. I know that If I leave a piece of it out after a while it gets very brittle.
c
No, it was on an inside wall. I suspect that the combination of age and cold coupled with the rapid expansion caused by going from 0 to 125 psi. It was good, but to save $$ I have been turning off the heat entirely and the accessories like air comp and exterior motion lights. The shop was down around 0F and the air was at 0 psi when I went in that day.
Oh well, even good temporary solutions only last so long....
jb
   / It's harder than it looks #26
What schedule PVC pipe was it that blew? I've seen schedule 80 PVC used for air lines that looked pretty safe to me.
   / It's harder than it looks #27
you cant use PVC in industrial/comerical applications because it is not impact resistant. (you only have to sneeze at it in a forklift and boom)
My dad and i have both used 1/2" PVC in our shops for 10+ years. The only issue ive had is snapping nipples off the ends. I have sence wized up and transitioned to black pipe about a foot before the QA couplers.
   / It's harder than it looks #28
gemini5362 said:
John I am curious about the problem with the PVC pipe blowing up on you. Did you by any chance have it out in the open where the sunlight could get to it. I have been told that ozone will attack pvc pipe and cause it to break down. I know that If I leave a piece of it out after a while it gets very brittle. c
Certain oils or coolants will cause the PVC to become em-brittled and weak. We ran some temporary lines in our tool room once while we were changing machinery layouts and they seemed to work so we left them up but after a couple of years they were blowing apart like the 4th of July so we changed them out to black pipe.
   / It's harder than it looks #29
OSHA's position on PVC and Compressed Air (You can take it or leave it, but note the 2nd sentence)
It is our position that PVC pipe shall not be used as a means of transporting compressed air. This position follows the manufacturer's own statements that PVC is unsuitable for compressed air systems. We do allow the use of certain ABS materials that are specifically designed for compressed air systems.
Reference: 19880520 The Use of Polyvinyl Chloride Pipe in Above Ground Installations.
   / It's harder than it looks #30
I have copper pipe in my woodshop and it has been there for about 5 years with no problems. I am running 3/4" copper stepped down to 1/2" and pressure is set at 100 PSI.
I once had PVC pipe in a portion of the water run for the chicken barn and the heater cable was turned off. Pipe froze and burst. Really a mess with particulate all over the place, no dead chickens though. I suspect that the pipes being at 0 degrees just couldn't take the cold.
2022 Club Car...
2007 Ford E-250 Cargo Van (A48081)
2007 Ford E-250...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
2022 Chevrolet Tahoe SUV (A48082)
2022 Chevrolet...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
1999 Allegro Bay Class A Motorhome (A48082)
1999 Allegro Bay...
