It's been awhile since I've seen something new.
   / It's been awhile since I've seen something new. #1
brain55
Brentwood, CA
I went to work on a customer's 2110 today. The complaint was that it had overheated and the oil was milky now. I expected it to be a head gasket, pretty straight forward. So I pulled the head, but the gasket was pristine. Now I'm starting to think cylinder liner electrolysis. I wasn't sure if this engine had a freeze plug behind the front gear case cover and hoped that was the problem, I already checked to make sure they were all in the head. I called a dealer that I use a lot, and they couldn't confirm that there was or wasn't. So I pulled the cover and there was no freeze plug. Now I'm left with electrolysis or maybe an internally cracked head. I unbolted the front end and slid it forward enough to get the driveshaft and oil pan off. I knocked the pistons out and didn't see anything that looked like pinholes in the liners, like you would expect from electrolysis. So I knocked out the liners, expecting to see corroded liners or damaged o-rings even though I didn't see any tracking in the crankcase around the liners. I had noticed the the #1 cylinder had gotten hot and moved some metal from the piston to the liner. After further inspection I finally found a radial crack near the bottom of the liner into one of the o-ring grooves. I was almost ready to call my machine shop to see if they could pressure test the head. I wonder if that piston seized at the bottom of the bore and cocked itself to crack that liner.
Brian
PS. I'll try to post some pictures of the liner tomorrow.
   / It's been awhile since I've seen something new. #2
Interesting discovery. I am sure you willl add that to your knowledge
base of experience. I have not seen that either.
I was salvaging some parts off of a free Infiniti V8 Al engine recently and
I saw something I have not seen before: the engine has dry cast ferrous
liners, but there is a lip on the deck that keeps them from coming out
that way (up). The bearing bosses/bulkheads are in the way of removal
thru the crankcase. I wonder...are these liners installed in the block mold
before the block is cast? There is no way to remove them without cutting
off the 1/8" lip on the deck.
2011 John Deere 120D (A47477)
2011 John Deere...
2020 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2020 MACK PINNACLE...
2012 Nissan NV2500HD Cargo Van (A51692)
2012 Nissan...
2016 Dodge Journey SUV (A53424)
2016 Dodge Journey...
2008  BIG TEX 16' T/A TRASH TRAILER (A53843)
2008 BIG TEX 16'...
2006 Nissan Xterra 4x4 SUV (A51694)
2006 Nissan Xterra...
