It's all in the timing
   / It's all in the timing #1
Uncle Levi
Bronze Member
Maxbass, north Dakota
John Deere 2020
I have an owner's manual and a shop manual for my JD 2020 gas and they both say when setting the timing, align the "s" or"28" mark on the front crankshaft pulley with the timing mark. I've looked all around that pulley and can't find that mark. How am I missing it ?
   / It's all in the timing #2
Have you seen the TDC mark? If so you can set the timing to TDC at slow idle. If the advance mechanism in distributor is working properly, that will put timing at 28 degrees BTDC at wide open throttle. Sometimes those marks can be hidden under paint.
10 in Small Excavator Bucket (A52377)
10 in Small...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
2025 AGT YC-32G (A50123)
2025 AGT YC-32G...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A53473)
2023 New Holland...
1267 (A50490)
1267 (A50490)
