It was a TORO GROUNDSMASTER 217D
   / It was a TORO GROUNDSMASTER 217D #1
JoBy
Timra
Toro
I bought a TORO GROUNDSMASTER 217D with a minor problem. A connecting rod had punched a hole in the engine block.
I took it apart.
After searching for another engine for a while I finally found a donor vehicle.
The Ford engine was only 4cm ( 1.5 in ) longer than the 2 cyl Mitsubishi diesel.
Fabrication starts ...
I removed this box ...
I had to find a new place for the alternator.
A new custom pulley that bolts to the TORO pulley.
And it is running again!
It started snowing so I made a simlple snow plow.
I had an old radiator and decided to make a slightley more serious snow plow from that. I used electrical actualtors to turn the blade.
Summertime and I needed a wheel loader instead. Very simple but it was much better than digging by hand.
Well, it seems like it want's to be a wheel loader ... time to get serious
An hydraulic pump, and a new pulley on the flywhleel.
A tower behind the seat.
Got some parts laser cut.
Building the lifting arms.
And the tilt mechanism.
DSC_0225.JPG DSC_0226.JPG*
I made an XY lever for the valve body
And a small video if the XY lever.
[video]http://www.joby.se/toro/xy-spak.avi[/video]
   / It was a TORO GROUNDSMASTER 217D #7
Wow I am impressed! :thumbsup:
Yours took a lot more work than mine. I have never seen a tilt system like that.
Glad that I inspired you to build it.
Tried to watch the video, but don't have the right codec for Windows Media Player.
Looking forward to the rest of the build pictures.
The tilt works very well. It has almost the same strength thru the whole movement, and it also has a lot of movemet. I can tilt the bucket almost straight down at maximum lift.
With the tilt cylinder at the rear I can also get the bucket closer to the front wheels.
Actually I found your pictures 2 years after I built mine.
This is the same video of the XY-lever uploaded to youtube:
Some more pictures of the hydraulics as it was when I first bulit it. ( It is a bit more complicated now :confused2: )
And a video showing the tilt mechanism with the rear mounted cylinder.
Moving some heavy wet snow. It will get a bit light at the rear when I get about 360 kg ( 800 lb ) in the bucket. The hydraulics will lift over 400 kg ( 880 lb ) at the front of the bucket.
2016 Autocar Xpeditor Garbage Truck (A51692)
2016 Autocar...
JMR 68" Root Grapple (A50121)
JMR 68" Root...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
2003 Honda 4x4 ATV (A50324)
2003 Honda 4x4 ATV...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
John Deere 3pt. 3 Bottom Plow (A50774)
John Deere 3pt. 3...
