sandman2234
Super Member
- Joined
- Dec 4, 2005
- Messages
- 6,150
- Location
- Jacksonville, Florida
- Tractor
- JD2555 and a few Allis Chalmers and now one Kubota
My JD2555 had been running most of the day. The batteries are old, and the starter has been dragging for a while, so since the last time I shut if off and it wouldn't start, I just leave it running if I am going to be using it in a few minutes. I got a phone call, so stopped and while sitting still, it just died. Kind of like somebody turned the key off. Restart didn't happen but the starter was warm from the engine so I wasn't surprised. Next day I go out and put a small battery charger on it. Checked the fuel, it has four inches in the tank. Hit the starter, and it fires right up, then dies like it did the day before. I am thinking fuel problem. I pulled the suction side of the low pressure pump and nothing, not even damp. I think that maybe the pump is bad, and it had gotten low enough on fuel that it wouldn't siphon anymore. It was right at the level of the pump, whereas I usually keep it pretty full. I changed the glass fuel filter about 25 hours back, but pulled it and it had some water in it. Not as bad as I have seen, but still some. I filled it back up with fresh fuel, added $30 worth of fuel to the tank and tried again. It did start, but only ran for 15 seconds. Grabbed a chain, and tried pull starting it. Again it fired, but dies within seconds, again, same thing, after that it won't even try to start. The way I see it, is I really need to but a new starter on it, along with new batteries, but I am going to have to wait until I am gainfully employed before I do that. I am thinking that the transfer pump might have quit, and after the level got lower than the pump, it quit siphoning fuel to the injector pump. My adding to the problem by breaking open the lines may have aggrevated the air in the fuel line problem. I may need to bleed the injectors, but what I don't understand is why it would start and then quit, and now refuses to start at all, even when being pull started.
I am pretty sure that I may need to look into the condition of the fuel in the bottom of the tank, just in case some accumulated trash has stopped up the suction hose.
Even one of my neighbors who works on cars, and sometimes tractors mentioned how good my JD2555 runs, which is why it is so frustrating for it not to want to start right up and run like it always does.
Anyone see anything else that I might be overlooking?
Also, I could use some help in the correct way to bleed a set of injectors, if anyone can offer a detailed account. It would be appreciated. I can probably get thru it, but detailed accounts often bring out critical things that should be adhered to. Thanks,
David from jax
David from jax
