There was a day when I wouldn’t have thought twice. I'd have spent whatever they wanted and I’d have a new battery right now. But now I am expecting a 3rd child, and with a stay at home mom, that means try to economize wherever possible. So instead, what I decided to do was to borrow a trickle charger (1.5 Amps) and run an extension cord to the shed. I cleaned off the corrosion and attached the charger at around 9PM. It has a green light to indicate charging (which was lit) and a red light to indicate charged (which was out). At 10:50 (less than 2 hours later) it is saying that it is charged. I guess I am assuming now that it is not going to take the charge. I’ll find out in the AM if it will run, but I am not holding out much hope. Is this what you all would guess as well..?
If I have to buy a new battery, $30 is quite reasonable. I’m not destitute or anything, I just thought that three years was not quite enough life to squeak out of a battery. Perhaps I was mistaken. Typically when I try and save money it doesn’t work. When I don’t try, it becomes painfully obvious that I could have.
Thanks for the replies everybody! Great info. I used the baking soda trick, and I did stop at Advance auto and buy the felt things for $1, but I forgot to put them on /forums/images/graemlins/crazy.gif (duh!)…
