It is started, couple of fluids questions for 545D
   / It is started, couple of fluids questions for 545D #1
clydesdale
Bronze Member
I got the tractor started. It was getting dark and I only ran it for about 2 minutes. I want to return to the site of the tractor prepared with the proper fluids, please excuse my ignorance.
Is there a coolant reservoir that will show the proper fill level and what kind of coolant does this model require?
What kind of engine oil and how much?
   / It is started, couple of fluids questions for 545D #2
My comments aren't specific to the 545D, but will work with most engines ever made.
Just bring some 50/50 mixed water/anti-freeze with you and some "diesel" rated (not super critical to be diesel rated) 15-40 motor oil. You should be able to find the radiator cap, fill it up, or at least get it within an inch of full. If there's a reservoir for the coolant, you should find a small hose coming from where you took the radiator cap off. The reservoir will have fill marks on it, but you need to look at the fluid level in the radiator itself, that's more critical.
Can't say how much oil it would take for a change, but I'd guess close to 5 gallons. If you're just making sure the engine has the proper amount to run, find the dipstick and check. You might want to bring several quarts (or get a gallon jug of Chevron Delo 15-40) of oil with you just to be sure.
   / It is started, couple of fluids questions for 545D #3
I'd put 15w40 C rated oil in the crankcase.. brand irrelevant, and any coolant that was fleet or diesel ready .. IE.. cavitation and electrolysis addatives included... for any hyds or power steering systems, including axles and such.. UTF fluid meeting M2C134D spec.
soundguy
   / It is started, couple of fluids questions for 545D #4
I think Monte meant 5 quarts, not 5 gallons. My truck takes 5 gallons, but then again it displaces 427 cubic inches...
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
2011 Kia Forte Sedan (A51694)
2011 Kia Forte...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51694)
iDrive TDS-2010H...
UNUSED Roof Thermal Insulation (A53117)
UNUSED Roof...
2013 Dragon Double Rail Roll Off Trailer (A53117)
2013 Dragon Double...
2020 Bell B30E Off Road Dump Truck (A53117)
2020 Bell B30E Off...
