Issue with Polaris Sportsman 500 - engine missing
   / Issue with Polaris Sportsman 500 - engine missing #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
OK, looking for some suggestions....
Got a 2005 polaris sportsman that is my farm quad. Worked well until this winter. Picked up a weird miss, in the upper range it just falls apart... under load even worse. Figured it was the carb...
Rebuilt the carb, adjusted the valves, new spark... Still is happening. Not sure where to look next other than ignition. Wondering if anyone had any thoughts... I don't think there is water in the pull starter... Not 100% sure until the cover comes off... It really feels carby the issue... Was wondering if my choke is leaking but it looked good (was not part of the repair kit of course).
Anyway, love to hear some suggestions as it is driving me crazy (or not driving me at all).
   / Issue with Polaris Sportsman 500 - engine missing #2
Saw the thread title in Today's Posts and thought your engine was gone! :eek:
   / Issue with Polaris Sportsman 500 - engine missing #3
Me too.... a missing engine is certainly an issue! :laughing:
   / Issue with Polaris Sportsman 500 - engine missing #4
Coil and plug wires would be next on my list.
   / Issue with Polaris Sportsman 500 - engine missing #5
My father was an English professor and part of my living is made from writing and I still amaze myself how poor of a writer I can be.
   / Issue with Polaris Sportsman 500 - engine missing #7
It dont make none diffrance on hear anyways! :D
Well, just as an FYI, I believe it might be the Cam. THey are prone to failure, and it sounds like what my engine is doing would be similar to the same issue. Apparently the cams for the engines do not have enough oil and the exhaust valves put a lot of pressure on the exhaust lobe, thus grinding it down. Will find out later this summer when I get back home.
   / Issue with Polaris Sportsman 500 - engine missing #10
A bad coil can cause the same problem. Works fine at lower RPMs, shorts out when high energy demands more power. Heat can also cause the same problem with the coil, or to the pick-up coil triggering the ignition system.
I'd look your ignition system over.
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A56438)
2006 Magnolia Dry...
2013 Ram 3500 Flatbed Truck (A59814)
2013 Ram 3500...
Carry-On 6'x8' Trailer (A53316)
Carry-On 6'x8'...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2010 Specialized Structure 1456 (A56858)
2010 Specialized...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
