Issue w/ my 2015 hst
   / Issue w/ my 2015 hst
I can hear the fuel pump working. When I bled the injectors on Sunday there was fuel coming out.
I took out the glow plugs and tested them. Two of them are bad. Here's the wierd thing: the two that are bad are numbered 0334 and the one that's still good is numbered 0361.
Why would here be two different glow plugs? My tractor only has 155 hours. Are glow plugs part of the warranty?
   / Issue w/ my 2015 hst #12
It seems like the tractor should have still started at least in the afternoon, even if the glow plugs aren't working.
When you turn on the key, how long does the glow plug light stay on? It should stay on 8 to 10 seconds, and if it only stays on a couple of seconds,your tractor needs a updated timer and glow plugs.
I will have to check the numbers on the glow plugs I have in stock, to see what is going on with your glow plug numbers.
Nowhere near 8-10 seconds. Typically around 3 seconds at the most. Can I adjust my existing timer or do I have to install new?
I'll be interested to hear what you come up with on the glow plug numbers.
Thanks!
   / Issue w/ my 2015 hst #14
I checked all of the used glow plugs that I have taken out of 2015's and replaced with the ones for the 10 second timer. They seem to have many different numbers on them, so I don't think the numbers on the glow plugs, mean very much. As for the timer adjustment, there is none, just a replacement timer which requires a wiring harness adapter, and different glow plugs. I have sent you a PM with a couple of ideas I could help you with.
New/Unused CFG Industrial QK16R Mini Excavator (A57453)
New/Unused CFG...
GRAIN BIN - APPROX. 14' ACROSS (A52708)
GRAIN BIN -...
UNUSED FUTURE FT20 EXCAVATOR (A52706)
UNUSED FUTURE FT20...
Sunray Family Fisher 17.5 18' Pontoon Boat (A53316)
Sunray Family...
SIMIRON SV3 HD VACUUM (A58374)
SIMIRON SV3 HD...
golf cart (A55758)
golf cart (A55758)
