Iseki TX1510 hydraulic suction filter/o ring replacement
   / Iseki TX1510 hydraulic suction filter/o ring replacement
Hi can you advise where the drain plug(s) are located?
   / Iseki TX1510 hydraulic suction filter/o ring replacement #12
Drain plugs for the transmission are near the bottom of the output shaft housings, facing towards each other just as the housings start to go vertical (the plugs are horizontal if I remember correctly.) I think they are a 3/8" NPT plug, maybe 1/2". The drain plugs are in a similar location on each of the front final drive housings. I don't think the fronts have a plug for how far you're supposed to fill it to. You just add a fixed amount of oil which I'd have to look up the amount for. Maybe a couple hundred milliliters. The main transmission has the dipstick of course.
2016 CATERPILLAR 730C2 OFF ROAD DUMP (A51246)
2016 CATERPILLAR...
2021 JOHN DEERE 7R230 LOT NUMBER 204 (A53084)
2021 JOHN DEERE...
PALLET OF (2) COMPRESSORS (A55745)
PALLET OF (2)...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
