Oil & Fuel Iseki TX1510 Fuel Cap Washer
   / Iseki TX1510 Fuel Cap Washer #1
ballaterach
Aberdeenshire,Scotland
Iseki TX1510
Hi folks anyone in the UK/Europe especially had to obtain a new filler cap washer and if so from where did you get it?
   / Iseki TX1510 Fuel Cap Washer #2
Some John Deere compact tractors were made by Iseki. Beyond that you may need to make your own.
   / Iseki TX1510 Fuel Cap Washer #3
Iseki was marketed in the USA under Bolens and White. Field Boss 16 is the same except the engine. AGCO dealer should be able to get you parts. The fuel cap comes complete with gasket and screen. Part #33-0011150 is what your looking for unless you wish to just make your own gasket. Brinkley and Hurst here in US might be able to get you parts. Hope that helps. Topzide
   / Iseki TX1510 Fuel Cap Washer #6
Here's a link for a cross reference,
Welcome to AGCO Parts Books
Go to guest section and the to White and the closest cross to yours is the Field Boss 16. Everything but engine stuff will cross. The Field Boss 16 is a 17hp. Hope this helps with your tractor. Any AGCO dealer can get most parts. I had to get input shaft, coupler and seals, gaskets to fix mine since was messed up when I purchased it.
I am pretty sure I have a spare tank (thats knackered) but it has the top on it should you not fancy getting a bit of neoprene and cutting one out.
or this pricey option, Iseki Fuel cap TA, TD, TE, TS, TX, TU - TP1194 - TracPartz
I took a full set of gaskets home from Europe, the stuff was home with in the week.
Chris
Hi thanks Chris I did buy a sheet of neoprene but it didn't seem to 'mix' well with the diesel think i'll try and source something else
   / Iseki TX1510 Fuel Cap Washer #8
I have found the fuel tank with cap, cap is there for the postage if you want it? the chrome is all gone but the washer is there.
Chris
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
LANESHARK LS3 LOT NUMBER 161 (A53084)
LANESHARK LS3 LOT...
2022 KUBOTA SSV75 SKID STEER (A51246)
2022 KUBOTA SSV75...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A53472)
PENDING SELLER...
2007 FELLA SM350 3 PT DISC MOWER (A53472)
2007 FELLA SM350 3...
UNUSED SWICT 78" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 78"...
