Iseki TU1700F Brakes
   / Iseki TU1700F Brakes #1
fireballxl5
Acton, Ca.
TU1700F
Does anyone know how to adjust the brakes on this model. It seems that only the right side is working any ideas?.
Any help would be appreciated.
   / Iseki TU1700F Brakes #2
The brakes are adjusted by shortening or lengthening the threaded rods that connect the peddle to the lever on the brake. There is one on each side just under the foot platform.
Hope this helps,
ok what if I do this and still no brakes on right side how do I check it out?.
Rick
   / Iseki TU1700F Brakes #4
You should just be able to remove your brake linkage and unbolt the round cover that holds the pads, etc. Then pry the cover off (the pads will come off with it). You should be able to tell what is wrong. Hopefully you will be able to fix it by adjusting the rod.
Aaron,
Thank u for the advise, adjusted the brakes yesterday with the linkage and they seem to work fine. /forums/images/graemlins/smile.gif
