ISEKI TS3110 Transmission Noise
   / ISEKI TS3110 Transmission Noise #1
Anonymous Poster
Epic Contributor
After the oil is warmed up in the transmission, When I let out the clutch in neutral, there is a fair amount of transmission noise. The noise is a little like a muffled old thrashing machine.
I assume that this is not normal. Might I be looking at a bad gear, bearing, or bent shaft on one of the gear shafts?
Thanks /forums/images/graemlins/confused.gif
   / ISEKI TS3110 Transmission Noise #2
By the description (noise when clutch is out in neutral) it sounds like it is the clutch throw-out bearing. This is a commonly replaced part, but requires splitting the tractor to replace.
   / ISEKI TS3110 Transmission Noise #3
I thought if the clutch was adjusted correctly (with the clutch out ) the throwout bearing would not be making contact with anything. With the bearing not touching it's not turning (no noise ). Sounds more like an input shaft bearing to me. /forums/images/graemlins/confused.gif
Rick
2000 GMC C6500 SINGLE AXLE BUCKET TRUCK (A57880)
2000 GMC C6500...
2004 MANAC 48FT CURTAIN SIDE SPREAD AXLE TRAILER (A57880)
2004 MANAC 48FT...
2016 Dodge Charger Sedan (A55853)
2016 Dodge Charger...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
Pick up bed (A55973)
