3-Point Hitch Iseki TS2810F/ Bolens G294 Hydraulic reservoir issue
   / Iseki TS2810F/ Bolens G294 Hydraulic reservoir issue #1
Isekirunner
Pittsfield PA
Iseki TS2810F
Well I decided to finally tear into the tractor. The issue I'm having is the hydraulic fluid has been low after every time I use the tractor. The problem is there are no leaks visible on the outside. Little while ago I had fluid foaming out of the shifter boot, so I figured the hydraulic fluid was leaking into the rear end. By the way nothing was wrong until I was running a 3pt backhoe on it for a year, they are too hard on the tractor for sure. Well I took the reservoir off and there is a pan underneath the tank. Now the new problem is that there is no visible hole or crack anywhere with minimal surface rust. in order for hydraulic to get into the rear end it has to leak through the pan. I see no other way that it can get into the gear oil. Has anyone else had an issue like this or know something I'm missing? Thanks in advance
Well I took the reservoir off today, cleaned all sealing surfaces and put it back together. Filled the reservoir up, started the tractor and watched the fluid level while I ran the fel up and down. Everything looked good so I screwed the reservoir cap back on and ran the tph up and down a few times and decided to check the level again just to make sure. Well I got the cap almost off and fluid started spewing out of the reservoir. Does anyone know why my reservoir is building pressure? Could the relief valve after the tph speed control valve be malfunctioning?
   / Iseki TS2810F/ Bolens G294 Hydraulic reservoir issue #3
Was it still "foamy" spewing out of the reservoir?
There was definitely little bubbles in the fluid. Probably 50/50 bubbles- fluid. I started a new thread in hydraulics. I tried moving this one but couldn't figure out how.
   / Iseki TS2810F/ Bolens G294 Hydraulic reservoir issue #5
I had a similar problem with my G154. The hydraulic fluid would bubble out of the
filler plug and then on to the ground. I realized that the oil foamed more
as it got colder outside. I finally figured out that the oil seals in the hydraulic
pump were old and hard and would suck in air as it got cold outside.
I rebuilt the pump and all is well now. I just used the tractor for
a couple hours today and it is still working good. It is cold here
in NJ and everything was working great. You more than likely
have a small hole or worn seal on the suction side of your pump.
check this link and start at post #170
   / Iseki TS2810F/ Bolens G294 Hydraulic reservoir issue #6
Thats what I was thinking fxrs, Iseki I am not familiar with your tractor, it sounds like you can see inside your reservoir while your tractor is running? can you see the hole/tube where the tph returns fluid to the reservoir? can you see where the bypass tube returns fluid to the reservoir?
There is no link to click. I would like to check it out.
John Deere 9470RX Tractor (A53342)
John Deere 9470RX...
New/Unused Quick Attach Auger with Three Bits (A51573)
New/Unused Quick...
2022 John Deere 333G Track Loader (A53342)
2022 John Deere...
EZGO GOLF CART (A50323)
EZGO GOLF CART...
2019 MACK GR64F TANDEM AXLE CEMENT MIXER TRUCK (A52577)
2019 MACK GR64F...
Tires (A50322)
Tires (A50322)
