Iseki TS2810 4x4, With Front End Loader
   / Iseki TS2810 4x4, With Front End Loader #1
Halfmoon5
Iseki 2810
HELP. I had been using it with no problems. Parked it for about a month, started right up shifted forward and then reverse . Then it would only shift in reverse . It has been raining a lot and it was not parked under cover . The gear oil was milky looking so Im in the process of changing It.
It is hard shifting to reverse but will shift back to N.
Also, the PTO will not work and it was working when I last ran it as was the transmission??
The lift front and rear work fine ?
Any ideas ??
Wanted to update . The tractor has 1,504 hrs on meter . Also the PTO Does Work . I changed the gear lube and the problem is the same . Thanks
   / Iseki TS2810 4x4, With Front End Loader #3
When it shifts into reverse does the tractor move in reverse?
Yeah , I can shift in and out of reverse , although it sometimes will jump out of gear . Other than from neutral to reverse , it won't move to any other position ...
   / Iseki TS2810 4x4, With Front End Loader #5
I would take the transmission cover off and look for obvious issues. I'm not familiar with the 2810 but it sounds like either the shift lever isn't properly engaging, there is a bent fork or there is something preventing a gear from sliding on a rail? It should be quick and easy to take the cover off and whatever the issue is will likely be pretty obvious.
2017 Nissan Titan (A55788)
2017 Nissan Titan...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A55314)
2022 New Holland...
2018 John Deere 2025R Tractor - 647 Hours (A55314)
2018 John Deere...
Case 950 8 Row Air Planter (A55315)
Case 950 8 Row Air...
2015 AMERITRAIL MANIFOLD TRAILER (A55745)
2015 AMERITRAIL...
205196 (A52706)
205196 (A52706)
