Iseki ts2400 fitting 3 point implements
   / Iseki ts2400 fitting 3 point implements #1
GaryR
Hi to all, very new to farming. I cant fit any implements to my tractor because the lower arms hit the rear wheels and are two narrow...the wheel base that is. My Fertilizer hopper and boom spray fittings are too wide....Can I reverse the rims safely to get the extra width...any suggestions? /forums/images/graemlins/confused.gif
   / Iseki ts2400 fitting 3 point implements #2
A typical catagory 1 3pt hitch is 26" wide between pins. How wide are your implements? Does the tractor have a standard cat 1 3pt hitch?
Do the arms hit the tires totally, or is it only that the arms are swinging back & forth & run into the tires when they swing too far? Then you need stablizers.
Most tractors can have the wheel width adjusted, however some small compact utility tractors do not allow (or recommend anyhow) doing so as it is too hard on the small axles/ wheel mounts. Check with your manual/ dealer on this.
--->Paul
Boat motor turns (A51694)
Boat motor turns...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
ECHO GT-225 GAS WEED EATER (A51248)
ECHO GT-225 GAS...
U56 DIESEL FIRE PUMP (A51406)
U56 DIESEL FIRE...
City of Buckhannon - 2000 GMC 3500 Service Truck (A52384)
City of Buckhannon...
2019 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2019 John Deere...
