Iseki ts2400 fitting 3 point implements
   / Iseki ts2400 fitting 3 point implements #1
GaryR
Hi to all, very new to farming. I cant fit any implements to my tractor because the lower arms hit the rear wheels and are two narrow...the wheel base that is. My Fertilizer hopper and boom spray fittings are too wide....Can I reverse the rims safely to get the extra width...any suggestions? /forums/images/graemlins/confused.gif
   / Iseki ts2400 fitting 3 point implements #2
A typical catagory 1 3pt hitch is 26" wide between pins. How wide are your implements? Does the tractor have a standard cat 1 3pt hitch?
Do the arms hit the tires totally, or is it only that the arms are swinging back & forth & run into the tires when they swing too far? Then you need stablizers.
Most tractors can have the wheel width adjusted, however some small compact utility tractors do not allow (or recommend anyhow) doing so as it is too hard on the small axles/ wheel mounts. Check with your manual/ dealer on this.
--->Paul
2011 CATERPILLAR 140M2 MOTORGRADER (A51246)
2011 CATERPILLAR...
2007 CATERPILLAR 330DL EXCAVATOR (A51246)
2007 CATERPILLAR...
2022 MGT CM11CUFT S/A Towable Concrete Mixer (A51691)
2022 MGT CM11CUFT...
2002 CRESCENT 102" X 53' STEP DECK TRAILER (A51247)
2002 CRESCENT 102"...
2013 JOHN DEERE 8235R LOT IDENTIFIER 191 (A53084)
2013 JOHN DEERE...
