Iseki TS1910 / Temp. Sensor
/ Iseki TS1910 / Temp. Sensor #1
texwoody
I need a Temp. Sensor for this tractor the light stays on all the time. I thank the Sensor is bad. Does /forums/images/graemlins/smirk.gif anyone know what will replace it or where I could get one.
Thanks
Tex Woody
/ Iseki TS1910 / Temp. Sensor #2
Ill bet if you pull that and take it to an import parts dealer you can get as many as want cheap........they are pretty standard.......Dennis
/ Iseki TS1910 / Temp. Sensor #3
Pull the wire off the sensor first and make sure it hasn't shorted to ground somewhere. If the light goes out it is the sensor for sure if not the wire is touching ground somewhere.
