Iseki TS1910 / Bolens G192 Wheels - What other Brand Models Fit?
   / Iseki TS1910 / Bolens G192 Wheels - What other Brand Models Fit? #1
palouse
Salem, MI
Iseki TS1910
I have an early Iseki TS1910, serial number 000020?. I have ag tires, I would like to get some wheels and tires better suited to lawn care, and keep the current tires and wheels. I have searched, not many advertisements reference actual pattern dimentions. Wheel makers that I have contacted are yet to respond. Currently tires are 4.00x12 front, and brand new 9x24 rear.
The rear wheel bolt & pilot pattern does not appear to be "standard" to small tractors. Front wheels may be more common. I would like to find wheels (probably 16"), and then worry about tires to match. If Kubota, Yanmar, or others would fit, then I will have more sources to look for. Can anybody confirm the following bolt patterns as being from another tractor maker or source? I can't find truck tires that match this pattern, either.
Is the following wheel pattern common with the Iseki TS1610 or other Iseki tractors? Thanks.
Rear:
  • 5.25" pilot hole
  • 6 lug, 6.5" hole center to opposing hole center (...holes form 6.5" diameter circle...)
Front:
  • 90mm (3.54") pilot hole
  • 4 lug, 130mm (5 1/8") hole center to opposing hole center
   / Iseki TS1910 / Bolens G192 Wheels - What other Brand Models Fit? #2
The TS1610 is the same. I probably have extra rims & some rear turf tires.
1263 (A50490)
1263 (A50490)
2019 ExMark Lazer Z S-Series 72in Zero Turn Mower (A51691)
2019 ExMark Lazer...
Curry Bac Bottle, 4700 gal bottle with pump/vac  (A52384)
Curry Bac Bottle...
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
2024 Greatbear 72in Vibratory Roller Skid Steer Attachment (A51691)
2024 Greatbear...
