Iseki TS1610 Solenoid questions??
   / Iseki TS1610 Solenoid questions?? #1
jfulps
lockhart, tx
Iseki TS1610
What could be the problem with the Solenoid?? I went to start the tractor and there was Nothing!! We have a brand new battery so that's not the problem!!
One thing is today we found out that if you give the Solenoid a few hits with a wrench or what not it will crank over and start!! What could be the problem there!!
I found one for like 50.00 Bucks or so !! Is that okay?? or is there a cheaper one or one that can go with a TS1610 that is cheaper??
Just let me know! I don't want to keep taking off the side guard and have to hit the Solenoid every time I start the tractor!!
Thanks
   / Iseki TS1610 Solenoid questions?? #2
It sounds like you should replace the solenoid. That is a sign that parts are worn out, and the rest will fail eventually and the wrench will not work. From what I found, %50 seems about average. You can look on eBay, but that is hit or miss. This is a good article that explains it in more detail and how to test you solenoid: Bench Testing a Starter Motor. I use Stevens tractor for a lot of parts, and if they dont have it listed, you can call, and they can often get it in. They have very good prices, and I think that they are in TX. Search results for: 'TS1610'
Good luck with it, and hope this helped a bit!
   / Iseki TS1610 Solenoid questions?? #3
I had a similar problem on my TS1610. Sometimes it would start and mostly it would not start.
When I pulled back the solenoid about a quarter inch by loosening the screws the tractor started. So I ordered a new solenoid for $32 and installed it. Same problem, it didn't fix it.
Then I tried cleaning and greasing the throw out assembly on the starter shaft. That assembly looked rusty. Then I installed the starter back in the tractor. Same problem again, it wasn't fixed.
So then I ordered a new starter. The new starter fixed it.
It order this part on ebay: "STARTER SOLENOID Chevy GMC Honda Isuzu Opel Blazer S10 Jimmy Civic Pickup
Item# 330717176336" The hot and ground were reversed from the orginal on this selenoid.
I still have the new solenoid on the old starter I removed.
2005 Isuzu NQR 4 door box truck with folding gate (A56435)
2005 Isuzu NQR 4...
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
CAST IRON POTS & KETTLES (A58374)
CAST IRON POTS &...
2022 Schulte 2500 Giant Rock Picker (A56436)
2022 Schulte 2500...
2017 Ford Explorer (A56859)
2017 Ford Explorer...
