Oil & Fuel Iseki TS 2205 won't start ran out of fuel!
   / Iseki TS 2205 won't start ran out of fuel! #1
DonWorrell
Pleasant View, TN
Mahindra 3325
Iseki TS 2205 won\'t start ran out of fuel!
As many of you know I ran my Iseki TS 2205 tractor out of fuel. I bled the lines and got it running again. It ran for about 1/2 a tank of fuel. I parked it and went out the next day and it would not restart.
We look for fuel at the top of the injectors. We had none so we think we had a small leak drawing in air. I emailed Derrick at Rainbow Distributors and he sent me a diagram on how to bled the lines. We did this. Tractor still won't start.
Now here are my questions.
1. We have fuel at the bled screw on the side of the injector pump but it won't pump pressure out the top.
Could we have some trash in the pump?
2. The tractor has 1040 hours on it. It looks in really good condition. No engine smoke. Good power. When I got it past overheating it pulls my 5' bush hog in 3' grass in 3rd low gear with no problem.
Could my pump just of gone bad overnight? Could I have a leaking seal?
How do you check the pump in the field? My engine is an Isuzu 2AB1. It is a 2 cylinder. Would any diesel pump mechanic know how to work on it?
3. If I need to rebuild the injector pump can I still buy an overhaul kit for it?
I know these are a lot of questions. But I am on a really tight budget and know a little about diesels but only know enough to get myself in trouble.
My neighbor is a gas engine mechanic and is helping me but he is at a loss now.
Thanks in advance for your help.
Don Worrell
   / Iseki TS 2205 won't start ran out of fuel! #2
Re: Iseki TS 2205 won\'t start ran out of fuel!
I do not know about Iseki but I you may have trash or water in your fuel filters. If they have not been replaced for a while get new ones. Fuel should flow freely to the fuel pump otherwise it does not get enough lubrication.
   / Iseki TS 2205 won't start ran out of fuel! #3
I think this is you fuel prime pump. have same issue changed fuel hoses and won't start again did pump little but not enough. so bypass pump and fill tank up till it is full. crank it and got fuel after a little bit and have it running again. now I am working on finding a fuel pump. with I will get from a yanmar engine.
   / Iseki TS 2205 won't start ran out of fuel! #4
Don, are you related to John who works at the big E in Springfield? I work with him.
Anyways, if you need Yanmar fuel pump, Hoyes or Fredricks can help. Fredricks is just down I-65 with a large warehouse of Yanmar parts for the imports.
New/Unused CFG Industrial QK18R Mini Excavator (A51573)
New/Unused CFG...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2013 Chevy Silverado 2500 HD (A53472)
2013 Chevy...
LMC LOT NUMBER 142 (A53084)
LMC LOT NUMBER 142...
2024 Sky Jack SJ45 AJT Man Lift (A51573)
2024 Sky Jack SJ45...
