Iseki TS-1610 Alternator Electrical Connector
   / Iseki TS-1610 Alternator Electrical Connector #1
rich_ncal
Northern California
TS1610
I am trying to put a new alternator on my TS-1610 tractor. New alternator I have is a WAI P/N 14129N ( Autozone Duralast 14129N).
The clearance for the body of the 3 pin electrical connector is a little smaller in the WAI alternator. But a bigger issue is the pin out is different.
Does any one know the part number of the connector to the TS-1610 or WAI alternator and where I can get this as a pig tail or a kit to assemble the connector?
Otherwise I will need to cut into the wires to the old connector and spice cross the wires.
The same WAI alternator also is used in 1971 Toyota picks trucks and early 70s Toyota Corollas.
   / Iseki TS-1610 Alternator Electrical Connector #2
You will probably have tocut & splice the wires.
I ordered an adapter cable, that I was able to modify to work. WAI part number 46-89807
I was able to push the male contacts out of the adapter and put them back in the cross over wiring I needed.
On the alternator end the body on the connector was a little too wide. I was able to shave down the plastic to fit.
All seems good. Alternator charging well.
NEW Work Saver Skid Steer/Sub Compact Grapple (A53473)
NEW Work Saver...
2022 Padget Morris Electric Mobility Scooter (A54815)
2022 Padget Morris...
2015 Toro Workman MD Utility Cart (A53421)
2015 Toro Workman...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
CATERPILLAR 22" PIN ON BUCKET (A52707)
CATERPILLAR 22"...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A55851)
Generac Yanmar...
