Oil & Fuel Iseki Tl2700 4wd fuel system issue
   / Iseki Tl2700 4wd fuel system issue #1
bapos
Need your help people. This is going to be a tad lengthly but should be laid out so you know all you need to know to help.
First off this is my first tractor ever. I am pretty good on maintenece of equipment but this being my first diesel I made a mistake and think I have fuel system issues.
Tractor ran out of fuel and had to pull it back to the house to get fueled and bleed to start up. It could not after lots of efforts.
Looked things over and the fuel filter was horrible. The bowel was not much better. I ended up getting a complete fuel assembly (filter,bowl, petcock, etc) and installed on tractor. Performed the bleeding and got the tractor running and not any problems.
About a week later mother reports the tractor will only run for less than a minute? Change filter again just to make sure it did not pick up trash in the whole process?
After bleeding the system from point to point I can get it to a point of what I think is the injector pump? This part is the last device before it pipes out to the head which I believe are injector lines and that would make that the injector pump. I can not get anything out of here which I would assume would be the problem.
Is there any way I can see if this is clogged, broken, or just plain jacked up? After talking to a repair shop he said they used 2 different types of injector pump? One is a rotatry and cant remember the other? He said they can be rebuilt which would be cheaper that new as always?
Is this a common thing? Any help would be appreciate. I can get pictures of what I am talking about if necessarty?
Thank you in advance
Bapos
   / Iseki Tl2700 4wd fuel system issue #2
The injector pump should have a bleed screw on it. The bleed screw is usually above the rectangular plate on the side of the pump. Your problem is probably air in the system , not a bad pump.
Well i hope this is the case.
I have bled it several times from every fitting and still no luck. I will probably take it in to a tractor repair center and make sure I am bleeding all the correct places.
Thank you for your reply
   / Iseki Tl2700 4wd fuel system issue #4
The bleeder screws all are 10mm with a phillips head.
   / Iseki Tl2700 4wd fuel system issue #5
Is there fuel TO the injector pump? Crack lines to each cylinder; BEWARE of fuel under pressure.
2025 New/Unused Wolverine 36in Hydraulic Backhoe Excavator Thumb (A51573)
2025 New/Unused...
2008 Ford Ranger Pickup Truck (A51692)
2008 Ford Ranger...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A53472)
John Deere 5090E...
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
