iseki tl 2701 f air filter
   / iseki tl 2701 f air filter #1
maho
arkansas city kansas
iseki tl2701f
looking to find an air filter locally for this tractor, need a wix, fram, or other number i can cross reference. Thanks, this site has been a lot of help. Mark
   / iseki tl 2701 f air filter #2
Hi Mark My TL2900 takes a Napa Gold #2276-051807G3. This filter seems to fit a number of tractors of the vintage, hopefully yours as well. Gerry
Thanks Gerry, got that crossed to a fram I can get locally. Fram#CAK256.
It was a good try, filter looked right, but was too big around and too long. I'll keep trying. Mark
   / iseki tl 2701 f air filter #5
Hey Mark Sorry to hear it wasn't a match. This same filter fits my 2900, a Hinomoto 2304 that I had and a Kubota L2402 that I recently bought. As a result I thought odds were good it would fit yours too. I'm sure someone will come along soon enough here with a # for you. If not, you'll have the fun of hunting it down yourself. One of the side benefits of going grey market. :) Gerry
Help. Surely someone knows what filter this tractor takes. I sure would appreciate some help. Thanks Mark
   / iseki tl 2701 f air filter #7
I finally got fed up trying to find filters for my Iseki. Although available, they were very expensive. My solution was to modify a VW diesel airbox to my engine and use FRAM air filters from Wal-Mart @ about $4 each. Calculated the pleated airflow area and actually was ahead using the VW.
Thanks svcguy, I'll try something like that. Hadn't thought of something that simple. Good idea.
   / iseki tl 2701 f air filter #9
If you do use a VW air box, I modified the height by cutting the bottom off of it. I then welded a simple bracket up and attached it to the firewall of the tractor. I think any airbox will do, as long as the calculated square inches of air cleaner surface is either the same or greater. Good luck!
New/Unused CFG Industrial NT18K Mini Excavator (A51573)
New/Unused CFG...
2022 New Holland Workmaster 40 Tractor with Loader (A51573)
2022 New Holland...
2018 JLG 3246ES 32ft Electric Scissor Lift (A51691)
2018 JLG 3246ES...
2000 Peterbilt 379 Truck, VIN # 1XP5D69X3YN487026 (A51572)
2000 Peterbilt 379...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
