iseki tl 2701 f air filter
   / iseki tl 2701 f air filter #1
maho
arkansas city kansas
iseki tl2701f
looking to find an air filter locally for this tractor, need a wix, fram, or other number i can cross reference. Thanks, this site has been a lot of help. Mark
   / iseki tl 2701 f air filter #2
Hi Mark My TL2900 takes a Napa Gold #2276-051807G3. This filter seems to fit a number of tractors of the vintage, hopefully yours as well. Gerry
Thanks Gerry, got that crossed to a fram I can get locally. Fram#CAK256.
It was a good try, filter looked right, but was too big around and too long. I'll keep trying. Mark
   / iseki tl 2701 f air filter #5
Hey Mark Sorry to hear it wasn't a match. This same filter fits my 2900, a Hinomoto 2304 that I had and a Kubota L2402 that I recently bought. As a result I thought odds were good it would fit yours too. I'm sure someone will come along soon enough here with a # for you. If not, you'll have the fun of hunting it down yourself. One of the side benefits of going grey market. :) Gerry
Help. Surely someone knows what filter this tractor takes. I sure would appreciate some help. Thanks Mark
   / iseki tl 2701 f air filter #7
I finally got fed up trying to find filters for my Iseki. Although available, they were very expensive. My solution was to modify a VW diesel airbox to my engine and use FRAM air filters from Wal-Mart @ about $4 each. Calculated the pleated airflow area and actually was ahead using the VW.
Thanks svcguy, I'll try something like that. Hadn't thought of something that simple. Good idea.
   / iseki tl 2701 f air filter #9
If you do use a VW air box, I modified the height by cutting the bottom off of it. I then welded a simple bracket up and attached it to the firewall of the tractor. I think any airbox will do, as long as the calculated square inches of air cleaner surface is either the same or greater. Good luck!
7022 (A50322)
7022 (A50322)
2018 VOLVO VNL DAY CAB (A52576)
2018 VOLVO VNL DAY...
2004 FREIGHTLINER CL120 TANDEM AXLE SLEEPER TRUCK (A52577)
2004 FREIGHTLINER...
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2021 FREIGHTLINER...
