Tires ISEKI Tiller 4.5' hitting tires need help whatz up
   / ISEKI Tiller 4.5' hitting tires need help whatz up #1
Anonymous Poster
Epic Contributor
ISEKI Tiller 4.5\' hitting tires need help whatz up
My tiller is hitting the tires on my 2004 hinomoto i'm not sure if it's the lower arms or top link is too long does anyone have specs on tipical lower arm lengths and tipical top links?
Can someone post pics of there tiller mine is a iseki 320 something.. looks like tipical jap tiller
Any pics would help me sort it out.. thanks!!
I have pics of the problem but they are too large to post..
   / ISEKI Tiller 4.5' hitting tires need help whatz up #2
Re: ISEKI Tiller 4.5\' hitting tires need help whatz up
There are 2 things you can do. Shorten the top link or make an adapter to extend your lower arm hookup 6".
Eugene
   / ISEKI Tiller 4.5' hitting tires need help whatz up #3
Fill out your profile with email address and I will send a picture of the setup. My pictures are too big to post and I don't know how to shrink them.
Eugene
   / ISEKI Tiller 4.5' hitting tires need help whatz up #4
I've got an Iseki TS2205 tractor with a Yanmar tiller. Attached is the setup I have. The top link is 8" and the lower arms are 26". One question - does your top link setup adjust? Mine has 2 adjustments, one vertical and one near horizontal (the tiller uses the horizontial).
   / ISEKI Tiller 4.5' hitting tires need help whatz up #5
Another pic. The tiller is a RSB1400.
my email is cat300hp@ nospammers hotmail.com
I cut about 4" off my top link looks like that did the trick mine is a iseki SRI320ca It had several diffrent levers and hitch pin postions.. Looks like it'll work.. though it was missing a bearing on right side making it sag to the right..
thanks agian..
   / ISEKI Tiller 4.5' hitting tires need help whatz up #7
On the majority of this Japanese tillers a special top link must be used or you have to move the lower lift pins of the tiller forward about 6 inches, and if you do that you usually have to get a longer PTO shaft.
   / ISEKI Tiller 4.5' hitting tires need help whatz up #8
After slinging 3 drivelines i've come to this conclusion you pretty much have to extend the lower drawbar hookups about 6-8 inches... to get enough movement for the driveshaft.. works great though.. Tough finding grease fittings though 8mmx90 degree..
UNUSED FUTURE 32" HYD TILTING BUCKET (A51248)
UNUSED FUTURE 32"...
24" SINGLE MANUAL RADIUS STEP (A51248)
24" SINGLE MANUAL...
UNUSED HURRICANE D6028 JOB BOX (A51248)
UNUSED HURRICANE...
2017 Freightliner M2 106 T/A 4,000 Gallon Water Truck (A51692)
2017 Freightliner...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51248)
(2) METAL SPOOLS...
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
