Iseki TA 255 Filters or info needed
   / Iseki TA 255 Filters or info needed #1
cowboy357
Platinum Member
SC Kansas
Looking for any info on filters or any other parts that might be available for My Iseki TA 255 , 3 cyl deisel 4wd .
I Need ,air & fuel elements , spin on oil & spin on hydraulic filters . I,ve searched this entire website as well as the internet & cant find any info on this model . I must have the only one . :eek: . I,ve finally exhausted My stash of the factory Japanese filters & have no good #,s to cross reference them to others that will replace them .
I,m down to just this one tractor after selling the other Isekis I had & its my workhorse . So I,m not looking for something close or "it might fit or work" , as I use it a lot . I know theres a few dealers on here that can supply certain things for other models & if You can help all info would be appreciated . You can either post here or PM Me . If You need pics I can provide them although I doubt it would help that much .
I plan on keeping this until I,m gone , So I might be interested in other spare parts & Buying enough filters to last Me for at least a few years . Thanks for any input . Bob
   / Iseki TA 255 Filters or info needed #2
I have a TA247 3cyl Diesel and had no trouble matching up oil and Fuel filters at an AGCO dealer. I have not tried the Hyd. filter yet but need to. Fram has a good replacement oil filter for mine.. I just opened a few boxes and matched them up at Wal-Mart Also NAPA. Like I said, I still need to find a Hyd. Filter. My 247 is a 25hp, 27hp,28hp or a 30hp, Depending on who I talk to.
Good Luck.
Thanks yomax4 , I just sold My ta 247 last year & I did let the filters I had for it go with it . They were different then this model .
I went back in every post made in this section & came across 2 fellas that had My same model also looking for filters & never got any replys . Being they were very old posts I doubt they even look in here anymore , But was hoping just maybe someone has the exact same model that would take the guessing out of it .
I,m in the middle of a pond Project & it wouldn,t be a good time for the oil filter to fall off due to it just being close & not fitting Exactlly right :eek: .
I,ll post a few pics , Of the filters on the Tractor just in case it might help . You might look at the spin on Hydraulic filter ( at least I think thats what it is in pic 3 ) on mine & see if it even resembles yours . My 247 did not have one like this . Thanks again , Bob
   / Iseki TA 255 Filters or info needed #4
This is the info I have on a TA 270. I think they are really close to the same motor. Hope this helps
Oil NAPA 1568
Air Wix 46496
Fuel NAPA3507
Hyd. Wix 51712
Oil NAPA 1568
Air Wix 46496
Fuel NAPA3507
Hyd. Wix 51712
Thanks so much Kays Supply . Thats at least a great start . Much appreciated . I,ll let Ya,ll know the outcome . :D . Bob
   / Iseki TA 255 Filters or info needed #6
Cowboy. You had a 247, Do you remember the hyd. Filter you used for it? Time to do a Hyd. Change. Also, My tires have tubes. Can you put fluid in tubes?
Thanks.
   / Iseki TA 255 Filters or info needed #7
The TA262 also uses a Wix 51712. That might be a place to start.
   / Iseki TA 255 Filters or info needed #8
Hi I have a ta250 and I was able to get all my filters at napa including the air filter ,which they had to order at 60 dollars.I just took in my old filters with me and they matched them up while i was there.:D
Thanks.
Yomax , I never had changed the Hydraulic in the 247 . I dont think it had a filter like this one But I beleive it has a screen inline that can be cleaned from what I,ve read , There is a few threads back in these pages that says which line its in I beieve though . If I run acrossed it I,ll post it .
Sorry I cant tell You about filling the tires either , I run all tubeless & never really had the need for more weight . Best a luck , Bob
Thanks Again Kays Thats good to know as well . Bob
63spyder , I,m not wanting to take the filters off untill I Know Darn sure I have the right filters in hand :D , Plus My wife will have to pick them up for Me & I,d like to make it simple as posable for Her .
Any chance You can post the Brands & #,s thats on Yours ? that would sure take some of the guess work out of it for Me .
Allthough Mine says 255 on the rear fender I finally found the tag last night with the model # & It is a TA 250F So it should be Identical to Yours I think . Got any pictures ? I was beginning to think I had the only one :eek:
Thanks again to all , :D . Bob
2011 Ford F150 (A50515)
2011 Ford F150...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
CASE 580M TURBO BACKHOE (A51242)
CASE 580M TURBO...
CUSTOM TRAILER (A51242)
CUSTOM TRAILER...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2015 INTERNATIONAL 4300 BOX TRUCK (A51222)
2015 INTERNATIONAL...
