Tractor News Iseki T7000 tractor PTO problem
   / Iseki T7000 tractor PTO problem #1
eru
Auckland
iseki T900
Hi guys I am seeking help .I have a PTO problem on my Iseki T7000 tractor. The out put shaft turns freely in neutral but won't engage when selected.
The machine has been parked up for sometime.
I have no parts manual to work with but if someone can email me ,eruwano@xtra.co.nz a scan of a breakdown on the PTO parts, pumps etc it be most appreciated
Thank you
Eru
   / Iseki T7000 tractor PTO problem #2
I wish I had the manual for you model, however I only have a repair manual for the TX model, that is much smaller than your tractor. Do you think that it is possible that the pto clutch is frozen? Some tractors have a pto ground speed lever that acts as a safety device, so when you you have the lever engaged, the pto will only spin when the wheels are moving. Is that a possibility?
Hi Mitch
thank you very mush for your quick responds.At the moment the person whom is trying to fixed my tractor is relaying through email to me the problem,because I'm not actually with the machine so I'm just going on what he writes or on the phone
I will take on board what you have given me. I know he has free-up the PTO clutch.I just hope anyone else read this can add on or scan me some information
Thank you Mitch
   / Iseki T7000 tractor PTO problem #4
Hi Mitch
Thank you Mitch
I wish I could be more help, but hopefully your mechanic can figure it out, and hopefully before it become too costly. I saw a post online of someone who had a similar problem with your model and it was dirt covering an orifice on the PTO engaging hydraulic circuit. I am not sure if that is what is causing your problem, but hopefully they can resolve it for your quickly! Best of luck !
I also found this thread where someone else had a similar issue. It looks like a White 2-65 is the same model tractor:
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=oliver&th=61865>
   / Iseki T7000 tractor PTO problem #5
our airport Iseke TG5570 won't engage the PTO hence can not run the grass cutter.
Cheers
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
2023 Bobcat T66 (A50120)
2023 Bobcat T66...
2013 Chevrolet Cruze LS Sedan (A50324)
2013 Chevrolet...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2016 Mack CXU613 T/A Wet Kit Day Cab Truck Tractor (A50323)
2016 Mack CXU613...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
