Iseki T6500+FEL, hydraulics are weak?
   / Iseki T6500+FEL, hydraulics are weak? #1
Mopig440
kubota L2850gst
Hi Team,
Downunder in New Zealand.
We have just picked up this little honey for a friend who was struggling with a lifestyle block herself witha few horses and cattle. She has a number of the large round silage bales. The main purpose for this tractor is to lift and feed out the larger size round silage bales, with silage forks. The bales are around 800kg.
Anyways, this tractor has an old Pearson FEL on it. All seals and rams been replaced prior to purchase, and can see where they have been dissasembled - so believe to be correct, and no external leaks on them at all. I can't hear any pypassing insde the rams, and its not that 1 is working well and the other isnt, and its binding.
I don't have a manual for it, and i'm struggling to find anything online to view ( but i'm not good with this sort of thing ).
However it won't lift the bale more than a coupe inches off the ground.
I have tried with not having the 3pt linkage at full up, incase its bypassing the pressure in pump - but no different when at half height.
Is there any relief valves anywhere in the system I can check to see if its bypassing, or is there any adjustment anywhere that I can give more pressure?
The complete tractor has been serviced about 50hrs ago with all fluids changed so not certain the oil is too old and thin.
Or is this just a sign the pump is weak and needs a rebuild?
Can any one advise where to download a manual? We need to know all the levers on left side of seat, for creeper gear, high / low and 4wd lever positions.
Thanks in advance.
   / Iseki T6500+FEL, hydraulics are weak? #2
There should be a relief valve in the loader control. If it is plumbed correctly, the 3point relief shouldn't have any affect on the loader. Put a tee with over 2000 psi pressure gauge in one of loader cylinder lines. Run the cylinder to the end of the stroke. The pressure reading is what the pump pressure is. Should be close to 2000psi. If it is closer to 1000psi the pump is bad. I can probably supply a pump if needed.
2018 Doosan C185 Trailer Mounted Air Compressor, Model 484289UBACG07, S/N C185WD20T4F, Deutz Diesel (A59076)
2018 Doosan C185...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
PALLETS OF HEAVYEQUIPMENT (A58216)
PALLETS OF...
IRTPL LIFT (A58216)
IRTPL LIFT (A58216)
2004 DCT PUMP TRAILER (A58214)
2004 DCT PUMP...
