Iseki Starter/Coil
/ Iseki Starter/Coil #1
FoodPlotsMan
My Iseki (Japanese of the US Bolens brand) 27 hp tractor is hard to start (and sometimes won't) when hot. Battery and alternator check out. I'm thinking it is the coil that sits on top the starter. Had the same trouble on a '69 Chevelle one time and it was coil.
Can anyone recommend where to go to find this part? I'd sure appreciate it!
Thanks.
/ Iseki Starter/Coil #3
I visit a Kabota Dealership here in Ontario Canada....some Kabota parts are the same and fit like the special air filter/oil filters etc. but the engine parts like the water pump/alternator/starter etc are Case International 255....I just picked up an exhaust gasket..next day shipping pretty quick....the Case International 255 has the same 3 cyl. diesel engine as whats in my Iseki...it pays to look around for options...for me bein' in Canada....it is way too exspensive for me for shipping and the US exchange....Ampa
Thanks folks. I appreciate the info. Some have already responded and unfortunately don't have the part, but I'm still trying. The info on the Case is very interesting. Didn't know that. Thanks to you North of the Border from this southern boy!
/ Iseki Starter/Coil #5
Try atrebuilders.com I have had them work on some grey starters. They sometimes even have rebuilts you can swap for your core. They show a new one for $175. That seems pretty fair to me.
/ Iseki Starter/Coil #6
Is this a gas engine, cause i didnt think any diesel would use a coil.
/ Iseki Starter/Coil #7
kind of late posting this if you have not found the coil also know as starter solenoid post the starter number and i will see if we have it in stock also in a lot of starters when they get hot and the bushings if they are worn out will also cause the same problem. hope this helps.
good luck
mitch becton
/ Iseki Starter/Coil #8
I am surprised to read about the CIH 255 in this thread. The IH 254/ CIH 255 was manufactured by Mitsubishi and I am surprised to hear that your Iseki shares the same engine. What model do you have?
/ Iseki Starter/Coil #9
I have the BOLENS (ISEKI) TX1704 (G174) this compact tractor has the Mitsubishi 3 cyl. diesel engine.... I lifted the hood on this Case International 255 and I was surprised to see this tractor had the same engine....at the same time I needed an exhaust gasket cause I had to remove the leftside shroud to get to the starter as I needed to wire up my new amp meter..which don't work anyway as I need a volt meter that displays volts/verses amps... anyhow the manifold had one broken stud so I replaced that while I had the whole upright muffler off.... the old gasket was stuck on the flange and I broke most of it... I was able to save half of it for a sample...but misplaced it.....I asked the young guy at the parts counter to order one for a Case International 255....I've since installed the new gasket with no problems....I also noticed that although the rest of this Case International 255(drivetrain) is not quite the same except for maybe the brake assembly which I noticed has the same plates on each side of the rear axle(drive) as my ISEKI...so I gather it would use the same brake drums and shoes....but like I mentioned I spend a lot of time looking at all the different brands at these dealerships...plus I ask many questions of what part will fit and which one won't...I found out recently I can buy a new rad core and take the core to any rad shop to install....and the rad core can be orderd from any Kabota dealer...so I hope all this new info on the ISEKI compact tractors helps some of you guys out there that are having a problem finding new and used parts..I almost forgot to mention I bought a new ignition switch for a Kabota and done away with the old two switch system...the spot where the one switch was... I've since installed a 12 volt cigarette lighter socket which comes in quite handy for when I need to inflate the tires on this tractor of mine....take care.....Ampa :):):)
/ Iseki Starter/Coil #10
I have the BOLENS (ISEKI) TX1704 (G174) this compact tractor has the Mitsubishi 3 cyl. diesel engine.... I lifted the hood on this Case International 255 and I was surprised to the same engine....at the time I needed an exhaust gasket as I had to remove the shroud to do some repair to also modify the wiring on the starter...the manifold had one broken stud so I replaced that.... the old gasket was stuck on the flange so I was able to save half of it for a sample...but misplaced it and told the parts guy to order one for a Case International 255....I've since installed the new gasket with no problems....I also noticed that although the rest of this 255 is not the same except for the brakes which use the same plates on each side of the rear axle...so I gather it would use the same brake shoes as my ISEKI....but like I mentioned I spend a lot of time looking at all the different brands...plus I ask many questions of what part will fit and which one won't...I found out I can buy a new rad core and take the core to any rad shop to install....and the rad core can be orderd from any Kabuota dealer...so I hope all this new info on the ISEKI compact tractors help some of you guys out there that are having a problem finding new and used parts...take care.....Ampa :):):)
Your Iseki number and your Bolens number do not match up. The G174 is actually a TX 1500 F The TX 17XX series would be a Bolens 19X.
/ Iseki Starter/Coil #11
These two numbers are on the front cover of my Bolens repair manual that I got when I first bought this tractor ... the small pic of my tractor is displayed on the top left hand corner of my posting board...you can see on the name plate it displays the ISEKI emblem which I've since removed it as cause it was broken....and also it is 17 hp and 4 wheel drive...I don't know what the "G" stands for but I do know the number 17 is for 17 hp and the 4 meaning 4 wheel drive....Ampa
/ Iseki Starter/Coil #12
The difference is that the Japanese reference the PTO horsepower... 15 Hp. The american companies reference engine horsepower... 17 hp.
I have an Iseki TX 1500 which cross references to a Bolens G172. I think the G stands for "Garden" tractor.
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61567)
2006 Generac...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63118)
2004 Cadillac...
(INOP) KUBOTA M9000 TRACTOR (A62130)
(INOP) KUBOTA...
New/Unused Quick Attach Double Hay Spear (A61166)
New/Unused Quick...
