Iseki purchase decision
/ Iseki purchase decision #1
SteveM
Upstate NY
Kubota B7100DT
I am getting close to purchasing an Iseki from Zephyr Knoll Farms in Upstate NY. Anyone deal with Chuck Mochamer? Anyhow, I am faced with the decision between a 4wd TS1610F or a 2wd TU1900. The TU1900 is a bit cheaper, but it is of course 2wd. The jump to a 4wd TU series is a bit steep for the budget. Any comments or feedback? It also seems that the TS1610 is a very near match to the Bolens G194. Am I correct?
/ Iseki purchase decision #2
If you can find the extra money for 4x4 you will not be sorry. I think 4x4 also holds it's value better on resale.
Good luck Chipperman
/ Iseki purchase decision #3
I have an Iseki TS1610F and have been very pleased. It's done everything I've asked of it without a problem.
I don't think the FEL work would be very effective without having 4wd to "push on in" to load. I run a 4' box blade, a 4' brush hog, and a 4' tiller behind mine.
/ Iseki purchase decision #4
I own a TS1910 and have never had a problem with it. Nice, heavy little tractor. I have used it to push snow in the winter (in AK), till in the spring and load (gravel/soil) in the summer.
I've read the warnings about 2wd and loaders in various threads on this site, but I for one have never had a problem with the FEL and 2wd - even with some pretty good loads. Of course, your results may vary... :)
Rick
/ Iseki purchase decision #5
I had a TS1610F when I built my house. I used a 6' blade to do all the backfill and grading. It truely amazed me. It is on the same frame as the next size bigger. That makes it beafier than most of the other brands the same size.
/ Iseki purchase decision #6
What do you want to do with your tractor? If you’re buying it to hold down tarps in your yard then I would go with the cheapest. /w3tcompact/icons/grin.gif Seriously decide what you want your tractor to do and buy the tractor that will do the top 75% on your list. If running PTO implements are important go with more HP if digging ponds in the spring is on the agenda then go for traction.
He is located in Dundee NY, in the finger lakes region. I am hoping to get out there in the next week or so to make a purchase, if everything is as he describes. Also, to update this helpful string, I have decided that I will 'raise' the budget a bit and go for the 4wd TU1700 if I do not like the TS1610...I dont think I want to live with 2wd again. I will keep you all updated!
Great new forum, by the way.
/ Iseki purchase decision #9
Listening to folks talk about the total wisdom and necessity of owning a 4WD unit makes me remember the Farmall A I've had for over 20 years now. It has 17HP, is crank start, is now 71 years old!, and it has only 2WD and I've never had a problem with it EVER!. A tractor owner/driver has to gain experience in driving tractors as I did back on the farm and one learns to compensate for darn near everything. That old A served me very well and while small Japanese tractors have various weight shortages, careful weighting and really knowing how to drive 'em goes a long, long way to getting effective performance from them. If you just came from the bowels of Detroit, yes, you need 4WD. If you grew up and started drivin' when you were 5, you really learned how to handle iron and you don't forget and very often you don't need tractors that have to be tricked up to get 'em to perform. Americans of the latest vintage went to American schools where nobody is left behind no matter what. They need a heavy Cat tractor with 4" growsers to get by on flat ground.
/ Iseki purchase decision #10
Listening to folks talk about the total wisdom and necessity of owning a 4WD unit.....
so true but when 1 has a brain fart and buries the SuperA to the drawbar and has to have friend come with 4x4 Ford p-up and 150' cable to pull it out reminds person real quick that doo doo occurs.
couple years later I buried his F250 4x4 and used same 150' cable couple snatch blocks and chains and large fir trees and pulled it out with the SuperA.
Trouble with 4x4 tractor is some people think they are unstoppable and when they do get them stuck they are really stuck.
take care and have a great one!
Paul
