Iseki Newb - Hitch Question
/ Iseki Newb - Hitch Question #1
Auburn, Wa
Iseki TS1610
Greetings. First post here.
Snagged this lean mean fighting machine last summer. TS1610 4x4 w/FEL, SAR? 1700 tiller, new rice patty tires that maul turf without pitty or shame, open ROPS, 300 hours if you believe the meter.
Its got some personality and punch for such a small tractor. Really enjoying it so far.
I've been looking at post hole diggers attachments lately. I'm not a tractor expert here. Searching the tractorbynet forums usually finds me an answer.
From what little I've discovered, I assumed the TS1610 had a Cat 1 three point hitch. Went out to measure before buying a post hole digger and measured 20" across the lift arms. 5/8" pins.
This is a category 0 three point hitch, yes? No category 1 implements for me. I'm not missing something am I?
All advice or knowledge on the tractor is welcome.
Thanks
/ Iseki Newb - Hitch Question #2
Here's the sizes 3 point hitch category sizes - Google Search . It is a CAT 0. I have an Iseki TM3160 and it's the same. I had a couple of implements that were for a CAT 1, a back blade and a scarifer I had made and they will work as the pins are the same diameter. Only thing is the clearance to the inside of the rear tire is close, I had to reverse the wheels to give me another couple of inches and the angle of the arms is not optimum as they're splayed out furhter than what they;re supposed to be......Mike
**EDIT** Actually I just looked at the sizes in the chart, the pins are CAT 1 size yet the spread of the lift arms is CAT 0, so I don't know what CAT size you'd call it
5/8" = Cat 0 if I'm reading that chart right. Thanks for the help Mike. Much appreciated.
Current three point system just looks janky to me I guess.
I'll order the Cat 0 post hole digger and update.
/ Iseki Newb - Hitch Question #5
Were you able to hook a cat0 atrachment to it.
2013 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A59904)
2013 FREIGHTLINER...
2023 FORD F-650 SUPER DUTY CAB AND CHASSIS TRUCK (A59823)
2023 FORD F-650...
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
(1) 300 GALLON & (1) 330 GALLON POLY TOTES W/CAGES (A60432)
(1) 300 GALLON &...
1997 JOHN DEERE 762B SERIES 11 MOTOR SCRAPER (A60429)
1997 JOHN DEERE...
2012 GENIE Z45/25J ELECTRIC BOOM LIFT (A60429)
2012 GENIE Z45/25J...
