Iseki g174 front end loader plumbing
   / Iseki g174 front end loader plumbing #1
Jared11
Iseki
So, new member! Bit of a tractor hoarder. Scored a cheap iseki Bolens g174 tractor and want to put an old loader I have laying around on it. Where would be best place to tap in? I have seen a few posts on here with the inlet and outlet tapped into the hydraulic manifold under the seat. Can anyone confirm this method is good aj explain it, probs the easiest for me but not sure if it’s correct way. Thanks everyone and help much appreciated, I’ve included picture of the tie In I want opinions on.
   / Iseki g174 front end loader plumbing #2
That would seem to be the logical place. It is also possible to cut the pressure line anytime after the hydraulic pump and just use the loader as a kind of loop on the pressure line. Of course quick disconnects should be used so you can easily reconnect the lines if the loader is removed.
LMC LOT NUMBER 269 (A53084)
LMC LOT NUMBER 269...
1999 Ford LA-9000 Aeromax Godwin Steel Dump Truck (A52384)
1999 Ford LA-9000...
New Long Forks (A53002)
New Long Forks...
Pallet of (6) 8 Lug Misc Wheels (A51573)
Pallet of (6) 8...
(4) 55 Gallon Drums of Mixed Laundry Detergent and Fabric Softener (A51573)
(4) 55 Gallon...
