Iseki g174 front end loader plumbing
   / Iseki g174 front end loader plumbing #1
Jared11
Iseki
So, new member! Bit of a tractor hoarder. Scored a cheap iseki Bolens g174 tractor and want to put an old loader I have laying around on it. Where would be best place to tap in? I have seen a few posts on here with the inlet and outlet tapped into the hydraulic manifold under the seat. Can anyone confirm this method is good aj explain it, probs the easiest for me but not sure if it’s correct way. Thanks everyone and help much appreciated, I’ve included picture of the tie In I want opinions on.
   / Iseki g174 front end loader plumbing #2
That would seem to be the logical place. It is also possible to cut the pressure line anytime after the hydraulic pump and just use the loader as a kind of loop on the pressure line. Of course quick disconnects should be used so you can easily reconnect the lines if the loader is removed.
2023 John Deere HD40F Draper Head (A53342)
2023 John Deere...
2010 Ford Fusion Sedan (A51694)
2010 Ford Fusion...
2008 24ft. Haulmark Edge T/A Enclosed Trailer (A52377)
2008 24ft...
2017 Club Car Carryall 550 Electric Utility Cart (A51691)
2017 Club Car...
Ryobi Sliding Miter Saw (A51573)
Ryobi Sliding...
EZ-GO MPT 1000 Electric Utility Cart (A51691)
EZ-GO MPT 1000...
