ISEKI 207 HELP
   / ISEKI 207 HELP #1
kcb420
ISEKI SA 207
I have an ISEKI SA 207 here and the three point hitch will not pick up a load. The bucket raises just fine but the 3ph will not. If I put the lever in the up position and get off the tractor and pull it up by hand, it will hold it there, and I can put my body weight on it and it will hold. I read that it could possibly be the valve that controls it. The speed is up but I have no idea where to go from here. Any help would be greatly appreciated, Thank you.
   / ISEKI 207 HELP #2
I know nothing about your tractor, but some have a turn screw, often under the seat, that has to be kept screwed in. If yours has one and it`s loosened a tiny bit, it will let the oil pressure go.
   / ISEKI 207 HELP
The drop rate valve is tight. It cant be that, thank you though!
   / ISEKI 207 HELP #4
I've never worked on a three point but it sounds like you've got fluid bypassing the controls internally somehow. You could have a worn valve or seal inside. Try to locate a parts breakdown for your three point hydraulic system. Lacking that look for information for other Japanese three point systems. I suspect in operation they're all pretty similar. I'm assuming you're using the proper quantity of the appropriate hydraulic fluid.
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
Case Ih 2388 Combine (A50514)
Case Ih 2388...
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
2008 GMC C7500 Altec LRV55 55ft Forestry Bucket Truck (A50323)
2008 GMC C7500...
Bobcat Skid Steer Forks (A50322)
Bobcat Skid Steer...
1999 Toyota Tacoma Pickup Truck (A50323)
1999 Toyota Tacoma...
