iseki 1910 hydraulic seals
   / iseki 1910 hydraulic seals #1
rjhans53
Mulberry, FL
Iseki 1910 Ford 8n B
I'm not even sure it's worth replacing at the moment, but I don't like fluid leaks. Seems to me that when I was a kid ALL the tractors leaked a little and we just lived with it. The pto seal is leaking (1/8-3/16 in a bottom of a paint can every other day). That seal is on the way and should be here tomorrow. When I look at the cut sheets I don't see any problem with this, looks like you take off the 3 point hitch plate, take out 2 bolts holding the pto sleeve. Pull the sleeve and replace the seal. Does this sound right, has anyone done this. The right arm to the 3 point hitch where it goes into the oil reserve (I'm not sure that's the right term but hopefully it's enough info to let you know what I'm talking about)has a really slow leak, but it leaks, I'm sure a quart of fluid every 4-6 months would replenish it but I would like to replace that seal also. I can not find anywhere to get one, any help would be appreciated
Thank You
Ron
I got the seals for the pto from gotractorparts.com. (Iseki, PTO Seal, (35x62x10mm), Fits: TS1610 TS1910 TS2205 - GoTractorParts.Com) The seal was only like 7 bucks, I paid for 2nd day and didn't get it for 4. They refunded 1/2 of the shipping cost with out me asking. But it didn't go quite like I had planned. The 3 point hitch plate held the seal in place, I went to pull out the shaft and that was a no go, I picked the seal out with a utility knife and a sharp pick and put the new on in place, put the plate back on and that was a done deal. It took about 3 hours and skin off of 3 knuckles but it doesn't leak any more. Funny There are 3 different exploded views in the manual I have, and this didn't match any of them. I'm still looking for the seals under the 3 point hitch arms.
   / iseki 1910 hydraulic seals #4
Someone posted that they contacted Iseki for an operator manual and Iseki responded with an operator manual. You could try contacting Iseki.
   / iseki 1910 hydraulic seals #5
I would dearly love to know how they contacted Iseki. I could use that information.
377811 (A48836)
377811 (A48836)
2003 Volvo S60 Sedan (A53117)
2003 Volvo S60...
2013 CHEVROLET TAHOE (A53843)
2013 CHEVROLET...
PALLET OF OIL COOLERS (A53843)
PALLET OF OIL...
1994 Trailmobile 51 ft. Dry Van Trailer (A53117)
1994 Trailmobile...
