Iseki 1610 PTO speeds
   / Iseki 1610 PTO speeds #1
jwscott
I have an Iseki 1610 with a 4 speed PTO. Does anyone know the rated PTO speeds for each of the 4 positions?
Thank you.
Jim
   / Iseki 1610 PTO speeds #2
Thank you.
Jim
I'm pretty sure #1 speed is 540 rpm and #4 is 1000 rpm, both at a given engine speed of around 2400 RPMs. The other two are in between somewhere, not for sure what though. I've used both #1 and #2 speeds with my Yanmar tiller (tractor: TS1610F). Anything faster is not necessary or desirable.
I'm pretty sure #1 speed is 540 rpm and #4 is 1000 rpm, both at a given engine speed of around 2400 RPMs. The other two are in between somewhere, not for sure what though. I've used both #1 and #2 speeds with my Yanmar tiller (tractor: TS1610F). Anything faster is not necessary or desirable.[/QUOTE
Thank you for your answer. I was guessing that #1 was 540 as it seems about that speed. #2 works well with my brush cutter for mowing down weeds and tall grass when I run at 2,000 RPM in 3rd gear M (of the H,M,L shifter). If the going gets tough, branches and the like, I shift to #1 and shift to a lower forward gear. I'm not sure what I would ever use #3 and #4 for since they are faster and most implements are rated for 540 PTO speed.
Jim
Jim
PS for some reason, the quote didn't work correctly on my first post so here it is again.
   / Iseki 1610 PTO speeds #5
I found the following posted on another site for the 1910:
I have a TS1910 and have found on the internet the speeds for the PTO
rpm's are 540,750,950 and 1250. The 540 is pretty close to true but
the 1250 is questionable.
2025 New/Unused Wolverine Skid Steer Land Leveler (A51573)
2025 New/Unused...
FIRESTONE 9.5L-15 4 RIB TIRES (NEW CONDITION) (A53472)
FIRESTONE 9.5L-15...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
SELLICK S80T4E-4PS ROUGHT TERRAIN FORKLIFT (A51246)
SELLICK S80T4E-4PS...
INSPECTION (A51572)
INSPECTION (A51572)
2000 Freightliner FL70, 5.9 Cummins (A52384)
2000 Freightliner...
