Is your loader bucket level?
/ Is your loader bucket level? #1
DK_Farms
South Louisiana
JD 4610 E-hydro 4WD, JD 5525 4WD Cab, JD 4066R
I have a 460 loader on a 4610. The bucket is 2 inches higher on one side versus the other. It came that way from the dealer. Nothing in the manual about leveling and the dealer says they never check that and wouldn't know how to fix it if nothing is obviously damaged or bent. I can't really see anything out of line. The cylinders on both sides always have the same amount of shaft showing in any position and the lift arms don't appear bent. Any ideas or is this normal? Never had a bucket before, just a shovel.
/ Is your loader bucket level? #2
Did you check the air pressure in your front tires?
/ Is your loader bucket level? #3
Ask you wife if she has noticed you being out of plumb..?
/ Is your loader bucket level? #4
Ok, real suggestion: Are both sides fully seated on the brackets in the rear?
/ Is your loader bucket level? #6
Ken, there's no way that's "normal". Of course, you need to check in on a firm, flat surface (level concrete preferably). Like the other guys said, unequal tire pressure may well be the only problem. The other possibility is improper installation. I would assume that Deere's loader manual has similar instructions to those in the Kubota loader manuals; one of those being to install it on a flat surface, putting the nuts and bolts in, but NOT tightening any of them until they are all in. It's hard to imagine the dealer not knowing what the problem is, and of course, I could sure be wrong, but I would think if the bucket were lowered to the floor and all the nuts and bolts loosened, it would settle level and then simply re-tighten all the nuts and bolts.
/ Is your loader bucket level? #7
The air pressure is one thing, as others have pointed out.
Mine was "out of level" and I fixed it by raising the loader all the way to the "top" figuring that at some point there was an imbalance of oil in the two cylinders. That did the trick, and the bucket was then level. I was worried at first that something was bent when I lifted from one bucket corner.
Hope this works for you. (And I would question the intergrity and smarts of the dealer if they told me what you said you heard them say).
/ Is your loader bucket level? #8
DK if the bucket is not level and you take the loader off you may never be able to attach it again. This cannot be correct. Complain to the customer rep. The dealer is not looking out for you.
/ Is your loader bucket level? #9
I would try Bird's suggestion. My 430 loader would never go on/off at all until I tried this suggestion from my dealer. Loosen all mounting bolts to hand tight and when the loader is installed properly then tighten them down good.
Thanks for all the suggestions. When I posted the question today, I had pretty much tried all the obvious stuff. Air pressure was correct, I was on a flat slab, tractor level, etc. I hadn't tried loosening any hardware, however. On the 460 loader, there are no bolts. The loader is all welded with pins at all the pivot points. The only bolted parts are the rear support arms that bolt to the tractor. Those stay on the tractor when the loader is removed. Nevertheless, this afternoon I set the loader down and proceeded to loosen the bolts on the support arms. When I did, the high side of the bucket came down to 5/8 of an inch off the slab. The arm on the high side came down alot and the short side arm came down just a little. I tightened everything up and measured the distance from the ground to the bottom of the support arms. The arm on the high side is about 3/8 of an inch higher. The only thing I can surmise is that the mounting arm was not welded exactly square on one of the the mounting plates. There are no shims or washers. One side is either too low or too high. Hard to tell which one without having another tractor/loader to compare to. I can live with 5/8 of an inch. My neighbor has a Kubota and his bucket is off about 1/2 inch also. As for my dealer, they are good folks but their smarts vary with the phases of the moon. Some days you get good info, and on other days you get double talk. Thanks again for the feedback.
/ Is your loader bucket level? #11
Sounds like the loader arms are tweaked, they are easily tweaked(not at the same height0). You need to tell your dealer to fix it now if it came that way.
/ Is your loader bucket level? #12
I assume this was new. I'd have the dealer come out and pick it up before I started using it. If you use it and then decide you want it to be level, then you may have a hard time proving that the bucket was off from the beginning. For whatever you paid for the tractor, you should have one that was put together properly.
I would contact the factory rep on the phone and follow it up with a letter to the rep and a copy to the dealer.
Even 5/8's of an inch is 5/8's of an inch too much. If you wanted one not properly lined up and bent all to heck, you might as well have bought a badly worn used one and saved yourself a lot of money.
The dealer expects payment in full for a factory fresh tractor and loader, you expect a factory correct tractor and loader.
If they can't fix it, insist on a new tractor/loader combination. Your neighbor should have done the same thing when he took delivery on his Kubota.
Joe
/ Is your loader bucket level? #13
Yep those mounting bolts in the back is what I was talking about. There is one more thing to try and that is to loosen the bolts by the latch plate in the front to hand tight and put the loader on with the rear mast bolts loose too. There are 4 bolts by the latch plate. Those moved quite a bit in my case to get the loader to work perfectly. Good Luck!
/ Is your loader bucket level? #14
</font><font color="blue" class="small">(
The only thing I can surmise is that the mounting arm was not welded exactly square on one of the mounting plates. There are no shims or washers. One side is either too low or too high. )</font>
If the arm is not square on the plate, perhaps arms and be removed and rotated to get the desired effect.
/ Is your loader bucket level? #15
My 2210 was delivered with the loader "off" by about an inch. Dealer came out, took it back and looked it over "no problem found"....since loader would sit level with ground when placed in float mode. I played with tire pressure - no results. So I lived with it. The loader and the grill/hood are parallel so I knew it was something with the tractor frame or rear tires.
This year I replaced my turfs with a set of bar tires. To my amazement, my loader is now perfectly level with the ground. Close checking shows that one of rear turf tires is larger in diameter than the other (at the same PSI).
Wouldn't hurt to measure the diameter of both rear tires.
Bobcat 435 FastTrack (A60462)
Bobcat 435...
KUBOTA RTV 900 UTV (A62130)
KUBOTA RTV 900 UTV...
2008 CHEVROLET EXPRESS VAN (A60736)
2008 CHEVROLET...
2014 TIELKE TRAILER 20 FLOAT UTILITY GOOSENECK TRAILER (A58214)
2014 TIELKE...
1993 International 4900 Utility Flatbed Truck (A60352)
1993 International...
2020 Bobcat T76 R Series (A60462)
2020 Bobcat T76 R...
