Is Yanmar 1100 or 1300 good enough for 2 acres?
   / Is Yanmar 1100 or 1300 good enough for 2 acres? #1
GRIZZLEY78414
Corpus Christi, Texas USA
Yanmar 1100 2wd
Got two acres I need to keep up with. Anyone know if the Yanmar 1100 or 1300 can handle a shedder well or a box blade. Maybe an augler?
   / Is Yanmar 1100 or 1300 good enough for 2 acres? #2
A neighbor down the road has a 1300 and a 3' or 40" / 44" rotary mower with it. He mows about 3 ac once every 2 months.
I think it's a 3' mower.. can't say for sure.. but that should also be fine with a 4' finish mower if you are looking at keeping it all as lawn.
A small auger should be ok on HP.. but I'm not sure you will get the lift clearance you need. Keep in mind that they make handheld augers with little 3+ hp gas engines.. your diesel is fine. again.. not sure you have the lift arm clearance for it though.
I havn't seen smaller than a 4' box.. though the KK XB line may have a 40 / 44" one. Should be ok if you can keep the tires from spinning. 4' angle blad would also be fine.
Think of it as esentially the same size as a riding lawnmower.. but with bigger nads...
If you had mor ethan 2 ac.. I'd go bigger.. say 1400/1500.. but the 1300 should do fine.
Soundguy
   / Is Yanmar 1100 or 1300 good enough for 2 acres? #3
1301D, 1401D or 1510D are nice.
   / Is Yanmar 1100 or 1300 good enough for 2 acres? #4
Looking through old forums, saw this on a Yanmar 1300 which is what I have. Dad told me to get a 5 foot finish mower, have the chance to buy a real nice 4 foot, with minimal use. Would a 5 foot be okay for this size tractor? 16HP Yanmar 2WD.
   / Is Yanmar 1100 or 1300 good enough for 2 acres? #5
I am using a 5' finish mower on my 1510. I haven't had any problems but your tractor is slightly smaller than mine.
   / Is Yanmar 1100 or 1300 good enough for 2 acres? #6
Go for the 4 foot. 5 is a little too heavy for a 1300. Not to mention that it is 2 feet wider than the tractor.
Eugene
   / Is Yanmar 1100 or 1300 good enough for 2 acres? #7
I'm using a 5' on my tractor with no problems, but the turbo is adding some power. I'm currently mowing the neighborhood park with it. The park is around 2 acres and it takes me 1.5 hours. Less in the fall when there is less growth. That said, I wouldn't want to use a manual shift tractor to mow with. Every time you push the clutch in you'll loose the pto and I find myself shifting pretty often.
   / Is Yanmar 1100 or 1300 good enough for 2 acres? #8
I have found that with a overrun clutch on the pto you don't lose very much when shifting. The momentum of the mower blades keeps the blades moving. I have a manual shift and primarily use the tractor for mowing.
   / Is Yanmar 1100 or 1300 good enough for 2 acres? #9
Thanks for all the great info. Bought a 4 foot finish mower off of ebay for 615.00. Have the receipt showing original purchase of 1250. Extremely Satisfied, paint not even scuffed. Mower advertised as only being used for 2 hours which I believe based on the condition. Here's a pic
   / Is Yanmar 1100 or 1300 good enough for 2 acres? #10
kmosabe,
looks nice. however, it's very small. are you sure it's 4' :D :D
Just kidding, looks sharp.
Komatsu WA250-5L Wheel Loader (A52384)
Komatsu WA250-5L...
2016 Chrysler 200 Limited Sedan (A51694)
2016 Chrysler 200...
2003 Chevrolet Silverado 2500HD Pickup Truck (A53117)
2003 Chevrolet...
2019 Bobcat E32i Mini Excavator (A51691)
2019 Bobcat E32i...
2009 Kubota RTV1140 (A50123)
2009 Kubota...
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A51691)
2019 Club Car...
