is trans too full d1650/st1620
/ is trans too full d1650/st1620 #1
texas
satoh st1620 4cyl diesel
sitting on the tractor pulling the plug on the left side by your foot fluid starts to come out instantly. is this the check plug for both the trans and the rear end and is it too full. just got this tractor and starting to service it before i work it. thanks for any help.:eek:
/ is trans too full d1650/st1620 #2
sounds like you found the transmission oil level hole. about half way up the case.
thanks there's another one on the right side behind your foot what would it be.
/ is trans too full d1650/st1620 #4
Valley Power
dont know your model .but some mitsubishis have the hydralic and the gear oil in seperate cases.i have the d 1850.it has one common case.
:confused2:i thought that to but there is only one drain and its on the bottom of the transmission. i dont see a drain for the rear end.
PALLET OF 15 4 X 8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4 X 8...
Case SV280B (A60462)
2016 Assembled Parts T800 Tri-Axle Dump Truck (A59230)
2016 Assembled...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58214)
HYDRAULIC AUGER...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2021 FREIGHTLINER...
