Is this truly a double acting hydraulic pump system?
   / Is this truly a double acting hydraulic pump system? #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
Double Acting Hydraulic Pump 12V Dump Trailer Pump 1 Quart Metal Tank/Reservoir | eBay
Is it power "up" but only gravity "down"? I notice that some of this type of unit have a pair of poppet valves while others have a directional type spool valve with a solenoid on each end.
Also, I see only one port on the one shown here so how could it power a double acting cylinder in both directions?
This one here seems to be true "double acting" but the statement below in the specs is a little confusing:
1 Quart Double Acting Hydraulic Pump DC12V Trailer Pump Metal Tank/Reservoir | eBay
2. [Dual function and quick start]-
The dump trailer hydraulic pump is made of stainless steel and is durable. Dual-effect power supply, maximum 3200 PSI. Increase the floating setting of the power; the maximum floating setting of port B is 1500 PS. It provides you with quick startup and long-term use every time.
   / Is this truly a double acting hydraulic pump system? #2
The ‘Chinglish’ and not knowing if the pictures are of the actual unit will make it hard to figure out till it’s at your doorstep! Sometimes you get what you pay for.
looks like they are both power up and power down.
I have power up-down in my dump trailer. I just recently priced a new pump/tank unit from a trailer dealer....$600 canucks.
Some people like gravity down, some don’t. Tomato-Tomato.
Yeah, I don't have a degree in Chinglish either. The different psi relief settings for up and down don't make much sense to me but perhaps there is a reason for is.
Edit: Perhaps the lower relief setting for "down" is to protect a safety latch under the trailer bed.
2012 GALLEGOS TRAILER 130BBL VAC TRAILER (A50854)
2012 GALLEGOS...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A51039)
2017 Yale GLC050VX...
2007 Terex RS350 Soil Stabilizer/ Reclaimer (A49346)
2007 Terex RS350...
2022 GTS FS35-G2 Flex Draper Header (A50657)
2022 GTS FS35-G2...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
INDUSTRIAL SAND BLASTER (A50854)
INDUSTRIAL SAND...
