Is this the typical BX front axle leak?
   / Is this the typical BX front axle leak? #1
magnatic
Southern Ontario
2006 BX2350
I noticed this leak on my BX2350. Then I did a search on the forum and found that others have experienced a front axle leak as well. Is it often in the same place?
I noticed that some indicated that switching to 80W gear oil may stop the leak, but I'd still prefer to change the seal and then switch the oil if that's what is recommended.
   / Is this the typical BX front axle leak? #2
That is what mine looks like.
   / Is this the typical BX front axle leak? #4
ya they are all the same i change both of them under warenty was lucky
   / Is this the typical BX front axle leak? #5
i have the exact same problem
   / Is this the typical BX front axle leak? #6
Switching to 80W90 should stop the leak. SUDT is some mighty thin stuff.
   / Is this the typical BX front axle leak? #7
be carefull washing it, what comes out can go in....
   / Is this the typical BX front axle leak? #9
Thanks I will do just that!!
   / Is this the typical BX front axle leak? #10
I was surprised to find out the front axle of my L3800 had SUDT in it.
I'll be replacing with 80W90 when I change it.
2021 Nissan NV2500HD Cargo Van (A56858)
2021 Nissan...
Hays LT1 Tender (A56438)
Hays LT1 Tender...
2012 Toyota Camry Sedan (A56859)
2012 Toyota Camry...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58216)
RAKE ATTACHMENT...
2012 DOOSAN G25 GENERATOR (A58216)
2012 DOOSAN G25...
