Is THIS The PERFECT Generator For The Next Two Or Three Years??
   / Is THIS The PERFECT Generator For The Next Two Or Three Years?? #1
CADplans
Elite Member
near Roanoke VA
584 IH 4WD
No gasoline, needed, so no ethanol to ruin the carb,,
HECK, NO CARB!!
You may need to get an AXE for your grandson for Christmas,,
so that he can keep the generator fueled,,
All I Gotta To Do is wrap this one up, so my grandson can get started building a firewood inventory,,
The only thing I do not like is that NO WELDING is required,,
I can not remember the last project that I did that did not need welding,,, :unsure:
Do you think I can get it running by 01/01/2022 ??
:ROFLMAO:
Before I start, what would YOU change to make this more functional, ,, or,, more FUN!! ??
Maybe,, I should make it a little larger, so that it can be mounted in the pickup bed,
then, at least, I will be able to STILL drive to the grocery store,,
   / Is THIS The PERFECT Generator For The Next Two Or Three Years?? #2
Here is a guy that has done this in moder times, in ww2 this was very common as it was no gas to be bought for ordinary people.
   / Is THIS The PERFECT Generator For The Next Two Or Three Years?? #3
On a car it is a bit more hard to place
   / Is THIS The PERFECT Generator For The Next Two Or Three Years?? #4
How to make it with a wood chip burner and automate it?
I guess the FIRST thing to do is make it power a WOOD CHIPPER, so, it could feed itself,,
or OTOH,, "simply" buy wood pellets,,, at TSC,,,
   / Is THIS The PERFECT Generator For The Next Two Or Three Years?? #6
I think "Useless" on the show Mountain Men uses one of these contraptions.
   / Is THIS The PERFECT Generator For The Next Two Or Three Years?? #7
Pretty cool!
Several years ago, while fueling up the pickup, a guy pulled in with one of those wood gasification rigs in the back of his pickup. I asked all kinds of questions, he used gasoline to start the truck, then switched it over to the gas from the wood powered converter. He just did it as a hobby type thing. I don't think he used pellets, because all i saw in the bed of the truck was small chunks of wood. Can't remember much of the conversation, unfortunately.
   / Is THIS The PERFECT Generator For The Next Two Or Three Years?? #8
Pretty facinating. During WWII Germany also had a process to convert Coal into basically deisel fuel for their war machine. I do not think it was this process.
   / Is THIS The PERFECT Generator For The Next Two Or Three Years?? #10
A video in Swedish but might be interesting
1985 Miller Wildcat 350-D Welder (A54811)
1985 Miller...
EZ-GO Electric Cart (A55853)
EZ-GO Electric...
2017 Gravely Pro-Turn 460 60in Zero Turn Commercial Mower (A55973)
2017 Gravely...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
2006 Toyota Tundra 4X4 Pickup Truck (A53422)
2006 Toyota Tundra...
