Is this Skid Steer Quick Tach conversion any good for a Kubota B2620
   / Is this Skid Steer Quick Tach conversion any good for a Kubota B2620 #1
JorgePR
San Antonio
Kubota, JD
Hello All;
This YINTATECH Skid Steer Quick Tach Conversion Adapter Bobtach Latch Box Weld On QTK, I am thinking of adding a quick attach to my tractor but don't know if this one is any good or reliable.
Any information helps.
Thanks
   / Is this Skid Steer Quick Tach conversion any good for a Kubota B2620 #2
Hello All;
Thanks
I bought a similar kit with the QA plate as well
I am working out issues
1) the plate steel is thinner than the 1/4 inch advertised
2) they machined the QA spring actuator incorrectly to where the handles cannot be rotated over the break over point to lock them I am machining the shoulder down so it will work.
3) The actuator part that slides is machined for a bushing that is not included therefore when you push the lever the assembly binds on the threads that keep the spring compressed.
I am trying to source or will have to machine those parts as well.
Maybe the company you posted has addressed the issues I am having with the kit I bought.
Hope you have good luck with yours should you buy
The prices are very competitive on these kits, but if you are not mechanically inclined or have shop equipment, a fully built SS QA from a well respected seller is a better idea.
sd455dan thanks for the reply I will keep the info in mind, I'll keep looking for something a bit more reliable for the money.
Thanks
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
John Deere S780 Combine (A53342)
John Deere S780...
2024 BRAZOS  53FT ALUMINUM STEP DECK (A52472)
2024 BRAZOS 53FT...
GENIE MAN LIFT (A52472)
GENIE MAN LIFT...
91013 (A48082)
91013 (A48082)
