Is this Skid Steer Quick Tach conversion any good for a Kubota B2620
/ Is this Skid Steer Quick Tach conversion any good for a Kubota B2620 #1
JorgePR
San Antonio
Kubota, JD
Hello All;
This YINTATECH Skid Steer Quick Tach Conversion Adapter Bobtach Latch Box Weld On QTK, I am thinking of adding a quick attach to my tractor but don't know if this one is any good or reliable.
Any information helps.
/ Is this Skid Steer Quick Tach conversion any good for a Kubota B2620 #2
Hello All;
I bought a similar kit with the QA plate as well
I am working out issues
1) the plate steel is thinner than the 1/4 inch advertised
2) they machined the QA spring actuator incorrectly to where the handles cannot be rotated over the break over point to lock them I am machining the shoulder down so it will work.
3) The actuator part that slides is machined for a bushing that is not included therefore when you push the lever the assembly binds on the threads that keep the spring compressed.
I am trying to source or will have to machine those parts as well.
Maybe the company you posted has addressed the issues I am having with the kit I bought.
Hope you have good luck with yours should you buy
The prices are very competitive on these kits, but if you are not mechanically inclined or have shop equipment, a fully built SS QA from a well respected seller is a better idea.
sd455dan thanks for the reply I will keep the info in mind, I'll keep looking for something a bit more reliable for the money.
2005 WESTERN STAR DUMP TRUCK (A60430)
2005 WESTERN STAR...
2000 Generac 2000 Series 30kW T/A Towable Diesel Generator (A59228)
2000 Generac 2000...
2012 Mini Cooper Coupe (A59231)
2012 Mini Cooper...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A61307)
2024 Kubota...
2011 FORD F-550 (INOPERABLE) (A55745)
2011 FORD F-550...
