Is this side link bent on purpose?
   / Is this side link bent on purpose? #1
opalko
Mississippi
1949 Ford 8N,2014 Kubota L3301
Kubota L3301. I was getting ready to till the garden spot this afternoon, noticed this when hooking up the tiller:
Thought I screwed something up royally, then came inside to check the interweb for a replacement to see how much cash I'd be out of and found this:
Adjustable Side Link
which looks pretty darn similar Is mine supposed to be bent or did I skrew it up?
Dukester
   / Is this side link bent on purpose? #2
its made that way
   / Is this side link bent on purpose? #3
I think the thread should be straight, with the yoke welded on at an angle. Might be the photo, but the threaded portion looks bent. Will it screw in all the way?
Bruce
   / Is this side link bent on purpose? #4
Do you need to screw it in all the way? If not, no problem.
But why thread it and bend it?
   / Is this side link bent on purpose? #5
Bruce
X2
Threads should be straight. They look bent. Try to thread it in.
Yes I managed to bend it somehow...I'll see if I can get someone to straighten or ante up for a new one. Thanks
   / Is this side link bent on purpose? #7
No need to straighten unless you have that much adjustment. And it is very hard to straighten threads and get it to thread freely again.
And if you need adjustment, while more of a PITA, you can always pop the top off the pin and thread in/out just the top.
Thanks - on my 8N someone tack welded the thing so there is no adjustment. What did I likely do that caused it to bend like this? Did I have it too tight? I don't even recall adjusting it after getting the tractor.
   / Is this side link bent on purpose? #9
Hard to tell which direction it is bent. But usually the cause is from pushing something in reverse, or side load that exceeded the swing allowed by the upper ball (and cause anti sway chains or turnbuckles were not tight to prevent that).
Have you used a rear blade or box blade and did some heavy pushing in reverse?
Don't have a box blade but I did have a heavy disc set on there recently. I'll pay more attention now!
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
Unused Delta Crash...
Ingersoll Rand Air Compressor (A51573)
Ingersoll Rand Air...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
1990 GREAT DANE 28' REFER (A52472)
1990 GREAT DANE...
U56 ELECTRIC FIRE PUMP MOTOR (A51406)
U56 ELECTRIC FIRE...
