Is this plume of smoke normal
   / Is this plume of smoke normal #1
botagreen
Northern Piedmont, NC
Kubota B7610
I'm a proud new Kubota owner and have little experience with diesel engines. When I crank the engine to my B7610, there seems to be a lot of white smoke that billows out for about 5 - 10 seconds and then it goes away. I assume this is normal but would someone help ease my mind.
On a separate note, thanks to all on TBN who take the time to write and respond to comments. It was an excellent resource for me when making my purchase descision. Very happy with my Kubota.
   / Is this plume of smoke normal #2
That's normal, just a little unburnt fuel due to the cold cylinders.
ron
   / Is this plume of smoke normal #3
I second the normal. The extra fuel is partially from the engine and cylinders being cold and partially from injecting extra fuel to aid starting. Sort of like a choke, except diesels don't have chokes - they have to add more fuel.
jb
   / Is this plume of smoke normal #4
Yeah go by a trucking company lot sometime when the temperature is 20 or below and they don't plug the tractors in and you wouldn't believe the smoke.
   / Is this plume of smoke normal #5
I had a problem with water in my fuel with my new B7800 that caused continous white plumes of smoke to come out the exhaust. I had to change the filter and then eventually drain the tank of it's fuel. After that I added PowerServe to the new fuel and everything is now good.
Every time I start up the tractor I have the initial puffs of white smoke and I wonderied why that is....now I know and don't need to worry
2016 FREIGHTLINER CASCADIA DAY CAB (A51222)
2016 FREIGHTLINER...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2009 JOHN DEERE 135D EXCAVATOR (A51242)
2009 JOHN DEERE...
2005 MACK GRANITE GU713 DAY CAB (A51219)
2005 MACK GRANITE...
2014 INTERNATIONAL MA065 CAB AND CHASSIS (A50854)
2014 INTERNATIONAL...
2013 Cadillac ATS (A50324)
2013 Cadillac ATS...
