Is this pine log worth anything?
   / Is this pine log worth anything? #21
The locust I harvested WAS at an old homestead. I've never seen groves of wild locust around here - pretty sure its a non-native species here also. Locust trees and fruit trees - you see them in your travels - pretty certain it involves an old homestead. Some of the very best apples I've ever had were from old homestead apple trees.
   / Is this pine log worth anything? #22
if its fat Lighter , It does have some value a bundle of about 2 handfuls will sell between 5 and 10 bucks. There is a little work involved but some money could be made if folks use wood for heat there.
It is not common for folks to heat with wood around here but it isn't rare either. I have 4 working fireplaces in my house and we have fires throughout the winter but don't rely on them for heat.
Usually when I get a stash of fat lighter I split it up and give it to people as gifts especially if they heat with wood. Nothing starts a fire better than fat wood. I also use it if I need to burn a brush pile. No need for diesel or kerosene. Just put a chunk of lighter wood with some paper under it up underneath the brush and light it with a match. Good lighter makes heaps of jet black smoke. Looks like you're burning a tire.
   / Is this pine log worth anything? #24
I have several fat logs that are very pitchy. a I know where several are that are still standing in the same place they were 40 years ago when I found them and the cat face markings are still visible
   / Is this pine log worth anything? #25
That is the kind of story that tempts me to do something with this tree. Large trees get blown over on my place all the time. Many of them I can't get to. Smaller, accessible hardwood blow downs I cut up for firewood. It just grieves me when I can't get to the more desirable trees. I hate to see them rot. There is a huge, tall, straight white oak, close to 24" in diameter rotting in one of my valleys right now.
My B-I-L neighbor hired a portable saw mill to cut up some huge cedars he had to cut down. For years there was a huge stack of sawn cedar on his place. A lot of it rotted but he got a number of cedar chests made, I used a lot of it to make the counter tops in my cabin and some other uses.
So maybe I'll drag the 12 foot piece out then cut the 25' piece in half and drag them out too. If I don't find use for them I'll make fat lighter out of them or give them away.
I've always wanted a saw mill but don't have any real reason to own one or any way to get a ROI.
In New Zealand Bee keepers love very resinous Pine to make their beehives The hive needs to be made from a timber that will last well out in all weather but can not use chemical treated timber as it kills the bees resinous pine fits the bill
   / Is this pine log worth anything? #26
Yes, they are non-native and most planted by homesteaders back in the day. Some plantings made later by the descendants. I clear cut several different stands that were dead or dying from the locust borer. Love that stuff, no better firewood in this part of the country. Cuts nice (with a sharp chain), splits easy and weighs almost as much dry as it does green.
   / Is this pine log worth anything? #27
When I cut my black locust(the ones without the thorns), sparks shoot to of the wood frequently. I eat a chain about every two tanks of gas, so I have 5 chains. It's ridiculously hard stuff. Around here, most of it was planted for erosion control because it has a large, shallow root system, and reproduces via suckers off of those roots. It grows very tall and straight as a telephone pole with branches only towards the tops, so it makes for easy felling, easy limbing (usually just crowning), easy hauling out of the woods, easy stacking like poles, and easy measuring for 16" lengths for firewood. The only thing I can't say is easy about the stuff is the actual cutting! Rock hard. :thumbsup:
Robinia pseudoacacia - Wikipedia
   / Is this pine log worth anything? #28
It weighs about 45 pounds per cubic foot.
Here is a little update. I finally got around to brining a 5' section of this log up out of the creek bottom. Then I stood that up and cut a slab out of it with the chainsaw. This is a piece from the upper part of the tree. It is not as resin-y as the bottom part by a long shot but it is still hard as a rock. I think I ruined my chain just making two two foot cuts.
Then I took it up on the porch and hit it with an old plane I have as a decoration in the cabin. It was hard to plane but I smoothed out a section and put a little mineral oil on it and this is what it looked like:
I know it just looks like yellow pine (I think it is actually a loblolly) but you wouldn't believe how hard and heavy this stuff is. I know it isn't worth anything but I like it and wouldn't mind having some boards from it. It will cost me to do it but I might do it anyway.
What I really want is a portable sawmill. As mentioned above I cannot justify one. It would not be for profit, just for usable lumber.
I'm toying with the idea of a community saw mill. There are several interested parties in the area (all family for what that's worth). My thinking is that I pay the largest portion of the price so it resides on my place most of the time. Each part owner will have his own blade and can only use his blade. Probably a big waste of money but the timber resources are there: pine, cedar, post oak, white oak.
   / Is this pine log worth anything? #30
Have you looked at an "Alaska Sawmill"? Just a hundred bucks or so but perfect for a couple of boards.
2017 FREIGHTLINER CASCADIA SLEEPER (A57880)
2017 FREIGHTLINER...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
2021 Polaris Electric Golf Cart (A56859)
2021 Polaris...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
