Oil & Fuel Is this normal with a BX2660?
   / Is this normal with a BX2660? #1
corey9212
Platinum Member
Red Deer County, AB
2015 John Deere 3046R
Today I was pushing snow and everything was working fine. I took a brake and always park the tractor in a heated garage. I went to start the tractor and knowticed that when I turned the key to heat the plugs and heard the fuel pump clicking it wasn't just a continuous clicking like normal it was sparatic stronger and weaker like it was pulsing. Is this normal or cause for any concern? I have about 150hrs on it.
Thanks.
   / Is this normal with a BX2660? #2
I will park my BX2660 in my heated shop and never noticed the pump click change. It seems standard if it sits 5 days or 2 hrs. Did it start OK? Maybe a connection was wet?
Jeff
Jeff
It did start ok, but I did knowtice it puffed out really dark black smoke when it fired up and it's never done that before (usually just a very small amount of grey smoke.) what connection could be wet to make it do that?
   / Is this normal with a BX2660? #4
2006 BX 24 710 hours. Has been doing the same thing since I got it.
Deano
   / Is this normal with a BX2660? #6
mine clicks while glowing plugs too. When its colder, it seems to be louder too.
Like I said the clicking is normal, it's telling you that your fuel pump is working but the clicks are usually regular and constant. Not get louder then quieter and sparatic (that's what mine is doing)
   / Is this normal with a BX2660? #8
Thanks.
This is the cold fuel and the act of starting the engine-even in a warm garage.
A Kerosene fueled salamander will warm the tractor up very quickly and to reduce engine wear. I use one the almost year round to warm up engines.
You should invest in a pressurised oil pump to pump engine oil through the engine prior to start up.
The act of starting an engine creates the most engine wear as the oil is not pumped until the oil pump is cranked by the act of starting your engine
The puff of black smoke is normal, its bit of diesel fuel consumed at start up and any remaining unburned carbon.
You worry when you have a lot of white smoke from unburned fuel.
If you have a lot of black smoke its usually due to a plugging or plugged air filter if the engine is in good condition.
Air filters are cheap, engines are not.
Auger Skid Steer Attachment (A56857)
Auger Skid Steer...
2007 50FT 3 CAR HAULER TRAILER (A58018)
2007 50FT 3 CAR...
2012 Ford Transit Connect Cargo Van (A56858)
2012 Ford Transit...
2014 International Derrick Digger Truck (A55973)
2014 International...
2015 Nissan Pathfinder 4WD SUV (A56859)
2015 Nissan...
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
